Old 04-04-2010, 05:14 PM   #1
mainermikeyd
mainermikeyd's Avatar
Edelbrock 8711 spacer problems
Well just installed a a Edelbrock 8711 spacer on my truck, previously just had a 1/2" open bore aluminum spacer. truck has Edelbrock performer intake, 1405 card , an now i have a noticible vacuum leak from the left rear {passenger side} carb stud. Installed a brand new Felpro base gasket an spacer to carb paper gasket, any one else had problems or is currently running this spacer?? Ive tried several times to reset everything with no luck am I missing something??
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 04-04-2010, 05:31 PM   #2
spinem
haha, ford guys...
Re: Edelbrock 8711 spacer problems
are you sure its not a vacc leak from dead center, back of carb? If so, i had this problem. You have a spread bore intake /w/ a square bore carb, using a SQUAREBORE spacer... not adapter.
you will need to return it and ask for a "SQUAREBORE carb to SPREAD-BORE intake spacer adapter."
but i could have misunderstood what you said and be totaly wrong
spinem is offline   Reply With Quote
Old 04-04-2010, 05:35 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
I would check the new spacer for flatness if it didn't leak with the old spacer.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-04-2010, 05:47 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I just put one of those on my Son's truck. The mounting took little time and there were no leaks. You may have gotten a warped one, as stated above or your gasket is not sitting right.
Frank
