Old 04-07-2010, 10:24 PM   #201
sourkraut
sourkraut's Avatar
Re: "The way it is" 67'swb
Originally Posted by CARZ1968 View Post
Is that bottom tag in korean?
carz I think it is??
Originally Posted by Slick67 View Post
POR 15 the inside of the air inlets!!!! POR 15.....I put that sh*t on everything!!!
slick I was going to por15 it but was worried about welding it then and what happen to it, so i used weldable primer and will paint the inside.
well was able to get some work done with the long weekend. i got my vent boxes buttoned up and got my engine completely done. got all the power steering hooked up and got my new alternator. i was not thrilled with the chrome finish but actually think it breaks it up and could not beat the price for a 1 wire hookup, internal reg and 110 amps.
the only think i am having trouble with is when i go lock to lock it has 1" to go on the pass side but the gearbox runs out of movement and can go/push past lock on driverside. do i have my pitman arm not in the right position on the gearbox? i thought i had it centered but must not have? if i am thinking correctly it goes in 1/4 incriments on the spine and am not sure if i just need to move it 1/4 turn in the correct direction so that it has the same distance? let me know what you guys think or if anyone ele has ran into this. thanks, enough rambling here are the pics.
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 04-07-2010, 10:39 PM   #202
msgross
msgross's Avatar
not bad... no idea on the gearbox...
how are you going to wire this rig? I have heard good and bad on the 1-wire deals...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-07-2010, 10:48 PM   #203
sourkraut
sourkraut's Avatar
you mean the alternator setup,right. i think i will use the one wire for ease and clean look. i know you can wire it with the plug but not sure of any advantage?
when you say good and bad, what have you heard. now you have me worried!!
Old 04-07-2010, 10:51 PM   #204
msgross
msgross's Avatar
only heard issues of using it with OEM amp gauges... but you are running aftermarket right?
The Garage:
Old 04-07-2010, 10:52 PM   #205
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-07-2010, 11:00 PM   #206
sourkraut
sourkraut's Avatar
i am not sure yet? i keep going back and forth. i like the look of both but have to do some homework to see if there is any way to get a stock speedo hooked up to the electronic sensor on my tranny?? i know they are mechanical but not sure if anyone makes such a thing or if i will be force to use a modern set of gauges.
Originally Posted by 72BlckButy View Post
Lookin' good!
thanks nate, your truck has given me a lot of get up and go to get mine done.
Old 04-14-2010, 06:23 PM   #207
Slick67
Sofa King Crazy!!
Slick67's Avatar
On the steering....line up the pitman pointing toward the steering wheel while it is in the straight position, then adjust the tie rods accordingly, driveway alignment!!! Should help some. The POR 15 was a joke!! I didn't do mine, but I did spray it well with a rattle can before and after welding (the best that I could through the kick panel vent) and it has good coverage!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 04-14-2010, 08:11 PM   #208
sourkraut
sourkraut's Avatar
Thank you for the steering advice! I did figure that out after some fiddling. Right now I an working on getting my clutch master cylinder figured out. I think I got it but have to do some rigging on the clutch pedal so that it work perfectly and the plunger does not come out of the back of the MC.
Old 04-15-2010, 11:18 PM   #209
sourkraut
sourkraut's Avatar
I finally found a clutch master cylinder that I would be able to use for my 99' nv3500 transmission. The one for this year did not have the ears to bolt it to the firewall and was a plastic snap lock. After going thru all of the late model years it was the 92'-94' mc and was able to use my hydraulic line that came with my tranny, so save some money.
Everything worked out great with the brake mc clearance and the way that i bolted it to the clutch pedal. The throuw length on the mc was 1.5" empty and was able to get a total 1.25" empty on the pedal with keeping the plunger on a parallel plane of +/- 1/8" which I am very pleased with. I dont think I will have to wory about the .25" loss cause I figure once it is bled it will hopefully only go an 1" or so with engaging the clutch fully. I have filled it up with fluid and pump it several times and had some pedal there but am going to leave it bleed it self some night till I try final bleeding the system.
Enough rambling, I know what you guys want!
Old 04-15-2010, 11:19 PM   #210
sourkraut
sourkraut's Avatar
and 1 more
Old 04-16-2010, 07:35 PM   #211
sourkraut
sourkraut's Avatar
Had got my clutch completely done today! Once I got the stop firgured out and welded on I blasted and powdercoated the whole set up and installed new plastic bushings. Now if I only had a truck I could use it in!
Old 04-17-2010, 08:05 AM   #212
msgross
msgross's Avatar
where did you get the bushings from? I assume that you PC'd it in pieces and then reassembled?
good work on the clutch..
The Garage:
Old 04-17-2010, 11:33 AM   #213
sourkraut
sourkraut's Avatar
i had gotten them from ece when i had placed an order from them. i forget the price but not bad at all.
yep tore it down and then pc'd and put back together. it turned out really nice and tight no woble or wear like it was before!
Old 04-24-2010, 02:08 AM   #214
highperf4x4
Subscribed!!
You've got some great work invested in this truck!
highperf4x4 is offline   Reply With Quote
Old 04-24-2010, 07:21 AM   #215
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Originally Posted by sourkraut View Post
A buddy of mine had brought his bike over to load up in the trailer for a bike show tomorrow. I thought you guys would like this picture. My friend made both my fender and his fender out of a flat piece of sheet metal! He used mallets and plenishing him to shape them, no stock fenders chopped up. He has some serious metal working skills and have learned a lot from him.
Those are so sweet bikes! I'd like to do a custom hardtail for the 77 Suzuki GS550 engine I've got. 2006 Spirit 750 too. Love the acid rust look too, which one's yours?
propanemudtruck is offline   Reply With Quote
Old 04-24-2010, 09:32 AM   #216
sourkraut
sourkraut's Avatar
Originally Posted by highperf4x4 View Post
Subscribed!!
Thanks Travis, I am getting excited to get the cab done and painted so I can move on to something else. I have the cab like 95% done outside of little clean up things. Then I got digging into drip rails and have some rust issues on the driverside that I have to take care of now.
Thank you propane mine is the green one, IT IS FOR SALE!! Those could be two neat little projects to do and be different which I love! I think it is neat when people do there own style!
Old 04-24-2010, 09:41 AM   #217
propanemudtruck
Very cool. I don't think there's one BAD bike out there, just some cooler than others! Feel free to check out my bikes on my photobucket. I think I have a couple cardboard sketches of the gs on there too.
http://s88.photobucket.com/albums/k1...02006%20SS750/
http://s88.photobucket.com/albums/k1...01977%20GS550/
awesome progress on the 67, every one of these builds I see I wish I could find a decent cab down south to bring home to my chassis!
Old 05-01-2010, 01:07 AM   #218
aboyer
Adam B
Nice progress, keep up the good work!
aboyer is offline   Reply With Quote
Old 05-01-2010, 02:00 AM   #219
highperf4x4
Yeah I need to do something with my drip rails too. What do you put back in there for caulking?
Old 05-01-2010, 09:28 PM   #220
sourkraut
sourkraut's Avatar
I have to rebuild repair mine. I had cut about half out and had to blast underneith. I think I am going to weld it back in and then calk them? I will have to do some homework before I do this will let you know.
I know what you mean about the cab, oh well looking back it was fun.
Checked out your bikes pics and they are looking good.
Thanks I am trying, getting there slowly.
Old 05-01-2010, 11:51 PM   #221
highperf4x4
Cool, thanks!!
Old 05-02-2010, 10:39 PM   #222
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice progress John! I believe you are talking about seam sealer (caulking) make sure to use seam sealer and not regular caulking.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-02-2010, 10:46 PM   #223
highperf4x4
Sir Heath. Can you provide more info on this seam sealer for us??
Old 05-02-2010, 10:51 PM   #224
my67chevytruck
Under Construction
how's this Travis? we used self leveling seam sealer above the windshield and along the doors, inside the cab we used brushable seam sealer. Napa, and a few other auto parts chains carries it, or you could always visit your local pain supplier....
http://lmgtfy.com/?q=3m+seam+sealer
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 05-02-2010, 10:57 PM   #225
highperf4x4
Thanks Heath.
Question though. If it's self leveling then how did you keep it from running down the side of the truck where the drip rail turns down behind the door?
