Old 04-08-2010, 12:20 AM   #1
6863m
Gas Tank in frame
I bought a special built tank from TEBOW in Florida to go in the 62 C-10 frame and it is 10" deep by 8" and I am a little confused by the different hook ups. I looked up sending units at Summit Racing and others and they seem to match the hole on the top of the tank. I also have a threaded hole in the bottom front for a fuel fitting. The sending units I have looked at seem to draw the gas from the top of the sending unit and a 3/8 tube. What is the hole in the bottom for if the fuel is drawn from the sending unit. Or is there a sending unit that is for the gage only and the engine fuel pump just draws it straight from the hole in the bottom front.
I hope I am being clear with my question. Also does anyone recommend a sending unit for my application.
Thanks.
6863m is offline   Reply With Quote
Old 04-08-2010, 01:04 AM   #2
Captainfab
60-66 Nut
Re: Gas Tank in frame
I'm not familar with that brand of tank, but most aftermarket tanks like that use a sending unit that doesnot have the integrated fuel pickup line In which case you would use either a port that is low on the tank, or one on the top only if it has a pickup tube going to the bottom. If you could post a pic of the tank we might be able to help better.
Old 04-08-2010, 07:12 AM   #3
lakeroadster
Perhaps the one on the bottom is a drain?
I was always told you never want a bottom mounted fuel pickup on a street driven vehicle 'cause it will suck any dirt into the fuel line.
A bottom drain on a fuel tank could prove to be very handy
lakeroadster is offline   Reply With Quote
Old 04-08-2010, 08:33 AM   #4
chevroletrestoguy
"I bought a special built tank from TEBOW in Florida"
That guy really DOES do EVERYTHING!!!!
chevroletrestoguy is offline   Reply With Quote
Old 04-08-2010, 10:13 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
pictures might help...
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-08-2010, 10:39 AM   #6
vin63
It's Better With Nitro
vin63's Avatar
Thanks.
As the others mentioned, a photo of your tank will help. Many of these tanks use a universal tube-type sending unit that is often made for fuel cells - you just have to get the unit that is close to the depth of your tank (they come in different lengths). While these units do not have a fuel pick up provision, the tank maker might have a part number for a conventional sending unit with a fuel pick up for a mechanical fuel pump application. Generally, the bottom threaded port you mentioned is used for the fuel pick up in a electric fuel pump application.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-08-2010, 10:52 AM   #7
tommys69/454
1969 short box
tommys69/454's Avatar
this might be what you are looking for http://www.summitracing.com/parts/ATM-3262/
tommy morehouse
tommys69/454 is offline   Reply With Quote
Old 04-08-2010, 12:05 PM   #8
aggie91
I'm just glad to be here!
aggie91's Avatar
It sounds like your tank is set up for a sending unit like the one tommy posted in the summit link and the fitting in the bottom is the actual fuel feed to the pump.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-08-2010, 07:54 PM   #9
6863m
I think the one that has been listed from summit fits the bill. I would assume that it is suitable for the 10" depth. I am also assuming that it sits on the bottom and measures the resistance as it uses fuel or adds fuel.
Thanks for the help.
