04-08-2010, 10:08 PM | #1 |
Need Help with Lifted 86
I ended up with a 86 shortbed 4x4 in a trade. It has a 6" lift and transfer case for 700r4. i'm new to 4x4's so here is my problem. the rear has 4 inch blocks. What did they do to raise it another 2" In the front, what did they do to get the 6" lift. I ask these question because I believe I want to bring it down some. i'm thinking i would prefer a 2" lift. How can i accomplish this, remove the blocks in the rear and do what to the front. also, will anything else need changed out, when you lift does driveshafts change. what could this person possibly done. it currently has no motor or trans in it now. thanks for help and advice!! tim
04-09-2010, 07:01 AM | #2 |
more ideas than money
Re: Need Help with Lifted 86
There are several possibilities of what they did to raise the front, but the best (and correct) way is to replace the spring pack. To return your truck to stock you should be able to take out the rear blocks and replace the front springs with stock springs. I have seen blocks and shackles used on the front before, but thankfully it is not often that people comprimise safety. You do need to check the pitman arm to see if the put on a raised pitman arm to correct the steering geometry. The driveshafts couls still be stock, most people try to avoid the expense of custom shafts, but you would have to measure to be sure.
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban Last edited by rwolf9653; 04-09-2010 at 10:25 AM. |
04-09-2010, 08:23 AM | #3 |
Kid's Mechanic
Just wondering,did you see the ride height before they pulled the motor??
Without everything together it might be tough to judge the correct height |
04-09-2010, 01:38 PM | #4 |
Chevys Kick A$$
Yea I was gonna ask that as well. Depends on how they lifted it could be 6" front and back just with 4" blocks and then 2" with springs.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
04-09-2010, 03:02 PM | #5 |
any pics?
Blocks are usually limited to 4" so I agree that they "might" have used 2" springs and blocks with 6" spring in the front. How do you know it has a 6" lift? New springs in the front for sure will be needed, you can try to remove the blocks as well and see how it sits with an engine in it... You should just buy a new kit online that will come with U-bolts, shocks and springs...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
