Old 04-09-2010, 07:07 PM   #1
Zonaman
Zonaman's Avatar
Little A/C Help, please.
I've got an Old Air 7200 Hurricane unit on my '69. It's been operating flawlessly for the last seven years. Yesterday it was going along fine and the compressor just quit- the fan operates fine. I can't seem to locate the problem. Here's what I've done so far:
* Static pressure is 65 psi at 70 F, both sides- enough to close low-pressure switch, right?
* tested dash switch with test light (light on) and then jumped termial plug (no compressor)
* tested evaporator thermostat terminals with test light- light came on
* Jumped low-pressure switch plug- no compressor. By passed plug entirely and connected wires - no compressor.
* tested reley- a 5 pin. It clicks when dash switch is engaged. With mulit-meter, no power pins 85 & 86 pulled 89 ohms; 30 & 87 0. With power; B+ to 85 & B- to 86, heard a click ; 30 & 87a 0; 30 & 87- 9. I think that's OK.
* All fuses & wires look good.
Did I make any errors or what should I be doing next?
Thanks!
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 04-09-2010, 07:56 PM   #2
Willys47
Willys47's Avatar
Re: Little A/C Help, please.
ohm the cluch on the compressor or just wire it to the batt and that should tell you if the cluch is bad
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 04-09-2010, 08:09 PM   #3
Zonaman
Zonaman's Avatar
I presume the one wire leading to the clutch should be connected at the B+ on the battery. How does one get a proper ohm reading off the clutch? It's a Sanden SD5H14.
Thank you.
Old 04-09-2010, 08:57 PM   #4
Chevydude56
Chevydude56's Avatar
Connect ohm meter to power wire and to ground/case of compressor.
Have you checked for 12V to the compressor clutch with the system turned on?
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 04-09-2010, 09:02 PM   #5
1971gmcshortbed
1971gmcshortbed's Avatar
^ What he said, jump power to the compressor clutch. See if it turns on, if it does work your way back.
1971gmcshortbed is offline   Reply With Quote
Old 04-09-2010, 09:08 PM   #6
ERASER5
ERASER5's Avatar
Pull the wire off the clutch. Measure ohms from the connector to ground.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-09-2010, 09:31 PM   #7
hayhauler71
hayhauler71's Avatar
Sanden compressors coils have a pretty high failure rate especially if the gap is not correct, if it has power to the compressor try to tap the clutch with a hammer handle while powered up to see if the coil can pull the clutch in.
hayhauler71 is offline   Reply With Quote
Old 04-09-2010, 09:39 PM   #8
Zonaman
Zonaman's Avatar
I think so- I bypassed the low pressure plug and ran the wire striaght to the compressor.
How many ohms should I see? Does it matter if the system is on?
Thanks guys, this is a great help!
