04-09-2010, 11:52 PM | #1 |
straight axle
Truck in question. 1969 GMC 1 ton (ex motorhome class b). The front end is getting quite sloppy. thinking about the amount of work involved with spring replacement, x shafts, ball joints, tie rods, center link, disc brake conversion etc. Pondering converting to a straight axle. This would entail basically a Dana 60 front axle without the differential center section. Converting to leaf spring. and going with a spring under to keep the truck at a reasonable height to keep the flat bed workable. Building, fabrication and converting is not a problem as I have the skills to complete. Any suggestions or thoughts?
04-10-2010, 01:00 AM | #2 |
Re: straight axle
I havw a few questions for you, 1. is this an 8 on 6.5 bolt pattern? 2. find a Ford F450 or smilar style Chevy, Dodge truck with a kingPin style axle, ALL will have leaf springs. this will make the ride ruff, but eadier to maintain
04-10-2010, 01:04 AM | #3 |
gets board easy.......
Re: straight axle
yeah,
sounds like a lot of work. How ever do you find the time to perform that conversion |
04-10-2010, 10:59 AM | #4 |
Re: straight axle
Not much different that converting to 4wd, just eliminating the diff and the t-case. I'm also looking at the time and expense of tearing the complete front end down and rebuilding it. That also is a full days work and then some with the disc conversion
04-10-2010, 11:00 AM | #5 |
Re: straight axle
Yeah, standard 8 lug. I'm currently looking into the super duty stuff and getting some measurements
04-10-2010, 12:55 PM | #6 |
Currently Blazerless
Re: straight axle
I have a magazine article here where a guy did that conversion only he used Dana 44 knuckles. He was gaining clearance for a Detroit 4-53. The trucks stance wasnt bad...I would think going spring under might set you to low.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
04-10-2010, 01:06 PM | #7 |
Insane In The Membrane
Re: straight axle
Why not just run a straight axle tube? Like the 2wd Ford F450-550's. It's the same as a front differential minus the actual differential part. Just has a tube going from left to right. Still solid axle but doesn't have all the diff guts.
Cameron Gunlock Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750 |
04-10-2010, 01:24 PM | #8 |
Location: Help! I'm in an office park with its own network of freeways!
Re: straight axle
The mid-'90s C3500HD chassis has a kingpin straight axle too.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
04-10-2010, 02:07 PM | #9 |
Re: straight axle
That's exactly what I was thinking of building with Dana 60 stuff. I will gain a much larger wheel bearing and still retain the same disc brakes and calipers as factory uses on the '71 +
04-10-2010, 02:08 PM | #10 |
Re: straight axle
04-10-2010, 10:23 PM | #11 |
Re: straight axle
Why not just use an I-beam axle? There's probably a company that sells them already modified with disc brakes for the older Chevy's.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
