Old 04-10-2010, 07:34 AM   #26
cdowns
cdowns's Avatar
Re: What kind of fuel mileage is every one getting
i think the overdrive tranny with those 308's you'll find not so good // you might get 14-15mpg
Old 04-10-2010, 08:25 AM   #27
eldogg
eldogg's Avatar
I've had a bunch of 73-87's with 355/700r4, 3:42, 28" tire & Q-Jets combos that would get 21-22mpg. Granted they would only get 12-16mpg around town. Maybe it helps that I'm great at tuning a carb?? Just my 2cents.
eldogg is offline   Reply With Quote
Old 04-10-2010, 08:29 AM   #28
mrein3
mrein3's Avatar
Originally Posted by molinehotrod View Post
I have 420 hp, 32 inch rear tire, 3.08 gears, 700r4 with 30% lower first gear and a taller over drive gear, i think it is .67. I think i am going to get 23- 25 miles per gallon.
Think is the key term above. I highly doubt you're getting 23-25 mpg.
The first thing you need to do is take your or a friend's GPS and get it receiving data. Find the screen that has mph or like on mine, "SOG" or speed over ground. Then find a 30 mph zone, get the truck going 30 mph on your speedometer, and record your GPS speed.
Then find a 45 mph zone and do the same.
Then find a 55 zone and do it again.
I bet your speedometer disagrees with your speedo by a long ways.
Once you get your speedometer corrected then figure out your mileage.
To do that is quite simple. Fill your tank full. Write down the odometer reading. Drive like you always do and fill your tank again when you need it. Write down the odometer reading and the fuel you put in.
Subtract reading 1 from reading 2. Take that difference and divide by the amount of fuel you put in the second time.
THAT is what your mpg is. Guessing by what a wrong speedometer (therefore wrong odometer) says or by counting mile markers is
When you get your speedo gears right and figure out your mileage the correct way report back.
FWIW, I get 10. My best ever is 13.4 when I still had a manual transmission and wasn't towing anything.
When I'm planning a trip where a tank full won't get me there I plan on 10 mpg.
I last filled the truck in November. I keep it off the salty roads but do plow my driveway and run it out to the fish house and back. I usually average 4-6 mpg in those conditions. I'll let you know when I fill it up this spring.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-10-2010, 08:59 AM   #29
LMN8UR
LMN8UR's Avatar
I have broke 19 mpg with the old 350 and everyone here thought I was full of then!
Last week I dropped a new 383 (the shop says it should be 400+ HP). Hope it doesn't kill my mpg, but who cares if it's fun! I'll let ya know how it comes out.
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 04-10-2010, 09:28 AM   #30
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
These trucks werent designed to get high mileage, I get about 10-12ish around town with the 350/350 3.08's, my speedo is about five miles off........you might get 20 if everything was made of fiberglass, but again with todays light made trucks and fuel injection they are barely getting 20 and thats after 40+ years of technology and thats a 2wd auto with od......I dont mind the gas cost because there is NO car payment involved.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-10-2010, 10:40 AM   #31
1quik70
I ran my 70 LWB with a 350/350 combo & 3.73's and normally got 15-16 on the highway. The carb was very well tuned, and the engine components worked well togther.
1quik70 is offline   Reply With Quote
Old 04-10-2010, 11:02 AM   #32
northburb
northburb's Avatar
The difference between "thinking" and "reality" is all in your mind.....or math in this case.
I think I'm good looking, the reality is... I'm ugly as a picked fence....
If it turns out you are actually getting that kind of milage, please share what your secret is....
I think I get about 8-10 in my burb...( never clocked it, to affraid )
1967 Short Wide
1970 GMC 4x4 PU
1971 Burb 4x4
northburb is offline   Reply With Quote
Old 04-10-2010, 11:37 AM   #33
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
The econo-boat can get 24-26 if I keep my foot out of it and loaf along at 70. However that's a TBI 305/700-R4/2.73 with 26" tires.
The truck used to get 11-13 when it had a 400 SB. Now it gets 7-9 with the 427. Same trans (SM420), same rear end (4.10), same tires (32"). I'm still tweaking the carb.
I did get 15 once with 30" tires & a 4.57 rear end. The speedo was also reading 20% high.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 04-10-2010, 11:38 AM   #34
Stocker
20' Daredevil (Ret)
Stocker's Avatar
mrein3, that's a great post on fuel mileage calculation. I'll add this: for greater accuracy, aside from filling up in exactly the same way every time, use the three-tank rolling average.
It's simple -- combine your three most recent tankfuls. When you fill up, add that one to your calculations and drop your oldest of the previous three. This helps minimize the inconsistencies and give you a more accurate consumption figure.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-10-2010, 11:58 AM   #35
mstrav1973
mstrav1973's Avatar
another thought would be to go on a 100 mile trip with a chase car that is accurate if you dont have the gps. Go about 50 miles and then come back to the same pump at the same station. my rig is a 4x so I would think 2wd would be 13-15 when well tuned.
what do the straight 6's get with a stick?
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 04-10-2010, 12:50 PM   #36
LONGHAIR
Not to "pile-on", because that is not what we need here....But it is faulty thinking that getting the lowest RPM possible at highway speed will net the best fuel mileage. You really need to be in the "sweet spot" of your particular engine. For mostly highway driving and the best economy at that speed, you should probably have a cam and corresponding engine parts that work best at around 2200-2400...and the gearing to keep it there.
In case subtle hints don't work......Play Nice.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-10-2010, 01:59 PM   #37
Stano
Stano's Avatar
fuel mileage? more like fuel footage! lol not really its like average 12-13mpg est with a mild 350 400t 3.73's and 275 60's on the rear. Turnin like 3000 at 70mph
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 04-10-2010, 02:34 PM   #38
72chevyk10
I built it
72chevyk10's Avatar
my 4wd 454 gets 13 on the highway with 4.10s and 35's and the t350 trans. im pretty happy with that. i get about 15-16 in town
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 04-10-2010, 03:54 PM   #39
eagleuh1
eagleuh1's Avatar
Talking Re: What kind of fuel mileage is every one getting
68 C20 327 Q-jet 4 barrel w/HEI TH400 4.56 with 33 inch tires got 10 to 11 mpg driving 10 miles out and 10 back from work every day. Usually didn't go over 65 because I had to pedal to fast.
eagleuh1 is offline   Reply With Quote
Old 04-10-2010, 04:04 PM   #40
68 longbed
4.3 v6 quaderjet 4 barrel, wc t5 trans with 308 rear 32 inch tire getting between 18-19 depending on way driven
68 longbed is offline   Reply With Quote
Old 04-10-2010, 04:08 PM   #41
big_al_71
big_al_71's Avatar
Maybe 9-10 mpg definetly smiling from ear to ear!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-10-2010, 04:10 PM   #42
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Sorry but I am calling this guy out.
Cuz myself I think he is jus trolling because there is no way he is getting this kind of mileage in a 1967-72 series pickup truck!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 04-10-2010, 05:20 PM   #43
John Knight JR.
70knight
Unhappy Re: What kind of fuel mileage is every one getting
I have 1970 4x4 3/4 ton tires are 33x12.5x16.5 gears are 410. With 350and 350 trans. I get 9 if i use 93 oct. Only.
70 4X4 KNIGHT
John Knight JR. is offline   Reply With Quote
Old 04-10-2010, 05:21 PM   #44
Jobe72
Jobe72's Avatar
Best I can tell...350/350 with 3.08 gears and 30" tires...10-12 mpg
so how big were stock tires?
1972 GMC Sierra LWB (Aquafresh)
1962 Cadillac Convertible
1962 Cadillac Sedan project
Jobe72 is offline   Reply With Quote
Old 04-10-2010, 05:21 PM   #45
eagleuh1
eagleuh1's Avatar
Don't take the bait and hook so deep then. Sorry.
Old 04-10-2010, 05:34 PM   #46
KFreddy
Active Member
KFreddy's Avatar
Operative words, I think...
Is this a riddle? 'Cause if it is I've got the answer; it's a diesel engine...
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 04-10-2010, 05:42 PM   #47
'72customdeluxe
420 horsepower diesel in front of a 700r4 800-900 lb/ft wouldn't play well with even the best built 700's
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 04-10-2010, 06:16 PM   #48
1971gmcshortbed
1971gmcshortbed's Avatar
Ahem,
http://www.transmissioncenter.net/700MegaRaptor.htm
1971gmcshortbed is offline   Reply With Quote
Old 04-10-2010, 07:00 PM   #49
fjthompsoniii
My 70 2x4 with 3.08 gear 350/350 with stock size tires, when well tuned eeks out about 14.5 mpg. However my 70 camino with mildly built 350/350 combo and a 2.56 gear will get 17-18 if you can keep your foot out of it. It seems like some times a higher horse engine that isnt totally radical will get better.... maybe cause it doesnt have to work as hard?
fjthompsoniii is offline   Reply With Quote
Old 04-10-2010, 07:31 PM   #50
tommys69/454
1969 short box
tommys69/454's Avatar
about six if I stay out of it!!!!! lol
tommy morehouse
tommys69/454 is offline   Reply With Quote
