Old 04-16-2010, 04:45 PM   #1
flat68
TH 400 info needed.
Hey guys. Just planning out my th400 crossmember build and had a few questions. I have my BBC sitting on p.o.l. mounts and i am not sure how high above the bottom of the frame rails the th400 mount is supposed to be. Any pics or info would be greatly appreciated as i dont have a factory mount to go by. Thanks!
flat68 is offline   Reply With Quote
Old 04-16-2010, 10:18 PM   #2
Fitz
Re: TH 400 info needed.
Here is a pic of my 67 frame with the stock small block/TH350 mount moved back to the alternate holes drilled for the big block, long snout trans combo. The height does not change, the pad for the trans mount is about 1/2 in above the top inner surface of the lower frame rail. After assembly of the cab I had to replace the stock trans crossmember with a CPP mount to make room for the exhaust. But, I just measured the height of the pad on the crossmember for the trans mount...1/2 in above the top of the bottom rail.
Fitz is offline   Reply With Quote
Old 04-17-2010, 10:05 AM   #3
flat68
Okay so bottom of mount is roughly 1/2 inch above top of bottom rail. does your engine/trans seem to be laying back a fair amount?? mine does and just curious to see if others noticed the same. Thanks!
Old 04-17-2010, 02:32 PM   #4
Fitz
It does but that's because I'm runnung the 68-71 big block frame stands. The 72 or 73-87 stands will drop the front of the motor by 3 1/2 inches letting you level the carb flange on the intake manifold.
Old 04-17-2010, 02:58 PM   #5
flat68
okay i see. mine does look a little lower w/ the p.o.l mounts but not much. just came in from garage and w/ trans mount 1/2 above bottom of rail my engine leans to the back a fair bit. only thing i can do really is set the cab on and run the jack under trans pan and see where i come into contact issues w/ low hump floor. thanks again for the helpful pics.
Old 04-17-2010, 07:37 PM   #6
flat68
Do you happen to have any pics of the cpp crossmember w/ your exhaust on?? i am test fitting w/ chevelle headers and want to keep all exhaust above or remotely even w/ bottom of frame and not below if i can at all help it. thanks again
