Old 04-16-2010, 06:57 PM   #1
my67c20
Installing Front Lower Bump Stops
Has anyone installed new front lower bump stops? What is the secret? Thanks
my67c20 is offline   Reply With Quote
Old 04-16-2010, 07:02 PM   #2
john
member #16
john's Avatar
Re: Installing Front Lower Bump Stops
Determination.
john is offline   Reply With Quote
Old 04-16-2010, 07:59 PM   #3
frankdatank01
heat em and lube em
frankdatank01 is offline   Reply With Quote
Old 04-16-2010, 08:00 PM   #4
frankdatank01
I also used a small flat screw driver to pry the one side down once I had one side in.
Old 04-16-2010, 08:27 PM   #5
cdowns
cdowns's Avatar
try and outthink them
Old 04-16-2010, 08:51 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
10 seconds in the microwave will soften them enough to make the job easier.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-16-2010, 08:59 PM   #7
Southcity
Southcity's Avatar
Originally Posted by frankdatank01 View Post
heat em and lube em
frankdatank01 is right. I replaced mine a few months ago and had to take them off and re-install just the other night as I wanted to trim them down a bit. Lubing them up both times worked for me. WD40 works good, does not leave a mess and will eventually wear away. Spray some on the bump-stop tab and try to press it in the slot on the a-arm. If you can get just part of the tab inserted (a small flat-head screw driver helps with that) then turn the bump stop clockwise and then counterclockwise (sorta of twisting it in but use a bit of finesse here so as not to rip the tab off) will allow for the rest of that tab to fall into place. Hope this helps. It also helps if you can get your Truck off the ground a bit or if you have access to a lift. Hope this helps.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-16-2010, 09:31 PM   #8
Ben IV
Yep Lube screwdriver and some cussin
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is online now   Reply With Quote
