04-18-2010, 02:21 AM | #1 |
Gen 3 Drive By Wire cruise control HOW TO
This write up describes how to hook up a cruise control switch to a drive by wire (DBW) 5.3L engine.
My harness is from a 2004 silverado. Other vehicles should be similar, but you’ll want to verify your pin out numbering on the TAC module yourself. I used a turn signal with cruise control handle is from Digital Dakota “HND-3”. This allowed this handle to be installed onto my van tilt column. The problem that I later realized with this handle is the set/coast and resume/accelerate do not work as they should to be compatible with the GM wiring harness. There may be other handles that work with the GM harness, but I already had the Digital Dakota handle so I wanted to use it. Basically, I used two relays to change the signals from the handle from normally open to normally closed. It’s not quite as simple as that since the handle powers the “resume/accelerate” when you push the “resume accelerate” button as well as the “set/coast button”. But the relays account for this too. So here are the parts you need: Qty 1 Digital Dakota turn signal handle with cruise DAK-HND-3 Qty 2 Relays (I used PCO-5591PT since it included a connector to the relay) Various butt and splice connectors and extra length of wires if needed Tools: Wire Stripping tool / crimp tool Test light Paint pen Wiring diagram of ECM and cruise circuit and this diagram: Step 1 Install the handle, ECM, and TAC modlule. All of my stuff was installed prior to hooking up the cruise control and the truck was running/driving great without it. Step 2 Find a suitable location for the relays. I mounted mine to the same mount that my ECM and TAC module is mounted to, which is in the cab out of the weather. I used a couple of self tapping screws through the relay mounting holes into the sheet metal. Step 3 I numbered the relay connectors so I didn’t get confused with the paint pen. I also removed the wires not needed from each connector. If you are using the same relays I used, remove the yellow wire from connector 1 (contact 87) and the pink/orange wire from connector 2 (contact 87a) Step 4 Wire up the relays as shown in the attached wiring diagram but don’t connect the wires to the TAC module. I used a EZ brand wiring harness and it included a “cruise power” wire. I connect this to the red wire of the handle. The yellow wire of connector 2 to the yellow wire of the handle Both green wires to the green wire of the handle Pink wire of connector 1 to the brown wire of the handle Blue wires of each connector to ground Step 5 Test your initial relay wiring with your test light. You will probably have to have your ignition switch on in order to power the cruise circuit. You want to verify that the brown/pink wire has power when you turn the switch to “on” Next, verify the red wire of connector 1 is hot when you push the “set/cruise” button on the end of the handle. Finally, verify the red wire of connector to is hot when you slide the slider on the handle to “resume/accelerate”. If these don’t check out, check your wiring and connections. Step 6: Connect wires to TAC module Connect the brown/pink wire to pin 14 of the TAC module (Grey wire) Connect the red wire of connector 1 to pin 4 of the TAC module (Dark Blue wire) Connect the red wire of connector 2 to pin 5 of the TAC module (Grey/Black wire) Step 7 One last connection There is one last wire from the TAC module that must be connected. It is a light blue wire from pin 6 of the TAC module. This wire connects to the brake switch wire that is hot only when the brakes are pushed. You’ll have to use your test light to determine which wire this is on your brake switch (especially if you are also running a transmission with a lockup converter) Not to hard to figure out, but this wire should be hot only when the brake pedal is pushed. This wire was labeled “brake switch” on my EZ wiring harness. Step 8 Test it out on the road Pretty much take out the vehicle and make sure all of the functions work. I suggest you take some tools with you and have your hand ready to turn off the ignition if something doesn’t work right as if you have not wired it up correctly there is a possibility of the cruise staying on and not being able to stop. If this happens, don’t panic, turn off your vehicle and pull over and figure out what you did wrong. Hopefully since we tested things in step 5 you won’t have a problem.
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 04-18-2010 at 02:34 AM. |
04-18-2010, 02:36 AM | #2 |
Re: Gen 3 Drive By Wire cruise control HOW TO
Printable wiring diagram
04-18-2010, 09:54 AM | #3 |
Great write up! I'll be doing this soon....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-18-2010, 09:59 AM | #4 |
Good write up.
72 chevy 3/4 ton 4X4 |
05-23-2010, 12:33 PM | #5 |
Thanks for adding this. I need to clean things up and add some more info also!!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
05-23-2010, 01:46 PM | #6 |
Good write up. I might be there soon as I get laid off and get back home to work on mine.
07-17-2010, 11:28 PM | #7 |
GM ONLY BABY!!!
Anyway to hook up cruise control on a 01 drive by cable?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
06-28-2011, 02:17 AM | #8 |
06-28-2011, 08:00 AM | #9 | |
1-mount the unit and hook it to the throttle body. Those CC units are used in a variety of cars with a variety of cables. Hunt around and find what will fit best. I have a Vortec truck unit in 1 vehicle and a Olds Ciera unit in the truck. 2-Hook up power and ground. Probably have to change the end on the power so it can plug into the fuse box. I think ground went to the block. 3-Get the brake switch from the donor vehicle and splice it into the brake light side. (orange and white wires). The brake pedal signal is needed, but is opposite of the brake light. Brake light is open with pedal in non-pushed position. Cruise needs power with pedal not pushed. 4-Hook up pulse signal. On speed-density TPI and early TBI, this is the same signal as the transmission/back of speedometer generates. Mass air TPI is 2000 pulses/mile and late TBI, Vortec, etc. is like 40,000. All of these have an output on the ECM/PCM for this 4K/mi signal regardless of the input. In my opinion, don't tap into the input, just get this as an output of the computer. On a non-computer vehicle you could possibly use a 4k/mile pulse generator off the speedo cable, but I have never tried it. 5-switches. If you can find a stalk to fit your vehicle, you can use it and not cut anything. If you can't and want to just put switches, the basics of operation of this system are simple. You need an on/off switch and a double acting momentary switch. The on/off is just that. The momentary gives 12V one way and you get set/coast and 12V the other way is for resume/accelerate. GM is very good at keeping wire colors standard, so if you can find a shop manual for any of these, you can get the colors. If you have any questions, I will try and answer them.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
06-28-2011, 09:20 AM | #10 |
Has more rust than truck...
06-28-2011, 09:52 AM | #11 |
GM ONLY BABY!!!
I think a few have done it over at the LS1tech site. Try searching over there in the Hybrids section.
06-28-2011, 01:16 PM | #12 |
X2 on LS1Tech site. I've seen S10 cruise control boxes used on the engine side. But you would still need a switch. You can get the wiring diagrams off LS1Tech or AllDataDIY. I made up a cheapo simple switch below dash to run my PCM cruise with, would work on the other as well. Its in my build thread somewhere.
06-28-2011, 06:32 PM | #13 |
Maybe this will save you some searching time. http://www.ls1tech.com/forums/conver...driven-tb.html
06-28-2011, 06:58 PM | #14 |
Second Chance Program
Thank you!
03-28-2014, 02:59 PM | #15 |
i realize this is old but the stop lamp supply voltage does that repalce the voltage supply from fuse box for standard brake lights?
03-31-2014, 10:49 AM | #16 |
No, it's a brake signal to the TAC module, you would hook it to the side of the brake switch that goes hot when the brakes are applied.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-26-2016, 08:21 AM | #17 |
I'm about to install my 4.8/4L60E in my 64 truck. I got everything from PSI yesterday(computer,harness,pedal,tac,etc) to get it up and running. I definitely want cruise once I'm driving. I found this stalk on Summit. Is it the right one ? Thanks for the information !
http://www.summitracing.com/parts/id...MobileSwitchNo |
06-05-2016, 08:07 PM | #18 |
Everything test out like it should with the test light all the switches on the cruise control lever light and unlight as it should. But take it for a test drive and we got nothing. Any ideas? Thanks
06-05-2016, 10:17 PM | #19 |
What exactly are you working on? Year, engne, trans, what switch etc.
06-23-2016, 04:40 AM | #20 |
Following this one !
11-03-2016, 06:57 AM | #21 |
I have this exact same HND-3 switch, but I am running a 2001 5.3 DBC, I am assuming that I still need to use these relays just because the brown wire supplies both?
11-03-2016, 08:16 AM | #22 |
Generation who? Drive by what? I thought I knew a lot about 67-72s and like to share what I know. But I'm lost on all this 21st century stuff. Maybe the LS Swap forum hadn't started back when this thread did.
11-03-2016, 09:04 AM | #23 | |
Check here: http://67-72chevytrucks.com/vboard/s...cruise+control http://67-72chevytrucks.com/vboard/s...cruise+control It wasn't. It should probably be moved.
11-03-2016, 11:17 AM | #24 |
Yes, you will still need the relays. Use the color schematic in the second pic, and wire your cruise module the same as he has his TAC wired.
11-03-2016, 11:19 AM | #25 |
You still selling your set up?
