Old 04-18-2010, 08:55 AM   #1
rain_man
rain_man's Avatar
what rear end do i have?
i have a 61 c10 i was replacing the diff gaskit and when i bought the one that autozone said went for a 61 in was a 10 bolt. i have a 12 bolt did the 61 come with 12?
i got the right gaskit we looked it up under a 65 el camineo
any help im wanting to upgrade my brakes in the rear and now im not sure if the rear end has been swaped out along the line
61 step/long bed SBW(SOLD)
NEED A NEW PROJECT
rain_man is offline   Reply With Quote
Old 04-18-2010, 09:46 AM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: what rear end do i have?
Can you post a pic?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-18-2010, 09:53 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
When your talking ten bolt vs twelve bolt, we are referencing the bolts on the ring gear to the carrier, not the cover. There should be a series of numbers / letters on the top right of you axle housing, not sure if its on the rear top or front top, which will give your an idea of what you have. Some where on this site you can decipher this...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-18-2010, 10:31 AM   #4
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Well, I learn something new every day. It's no wonder I get confused with these axle ID's, all the sites you go to show pictures of the covers and ID them according to the number of bolts.
I just saw that chart with the ID numbers not long ago on here.
rain man, do you have 5 bolt wheels, which is what an El Camino should have had, or 6 bolt?
Larry
fleetsidelarry is offline   Reply With Quote
Old 04-18-2010, 10:42 AM   #5
fleetsidelarry
Senior Car Nut
Duh, right up at the top:
http://67-72chevytrucks.com/vboard/s...d.php?t=327764
scroll about half way down to see a readable version
Larry
Old 04-18-2010, 11:46 AM   #6
CSGAS
optomistic ah-so
CSGAS's Avatar
Almost 50% of my recent experiences with Autozone have involved the wrong part in the right package.
On my last (hey, is that a double entendre?) return, the counter worker needed me to tell him the part I was returning was a master cylinder, while it was out of the box on the counter in front of him.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 04-18-2010, 02:03 PM   #7
rain_man
rain_man's Avatar
12 bolt cover and i have a 6 lug
the po had this truck all choped up i know the engine is from a 65 el camino the trani is ??
he said he had swaped out the rear but wasent sure what it came from
(po was a old red neck crazy guy)
NEED A NEW PROJECT
Old 04-18-2010, 03:03 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
While it is true that 10 or 12 bolt refers to the number of ring gear bolts, it will most certainly coincide with the number of bolts holding the cover on too. Very few GM rearends had 10 bolt ring gears and 12 bolt covers. I've read about them, but me or anyone I know has ever seen one that the cover bolts didn't match the ring gear bolts in number.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-18-2010, 06:34 PM   #9
rain_man
rain_man's Avatar
yea i thought they were allways the same
i allways just go by the bolts on the cover
anyone know if the 61 had a 10 or 12?
NEED A NEW PROJECT
Old 04-18-2010, 06:49 PM   #10
fleetsidelarry
Senior Car Nut
I think they came with a 10 bolt. My 61 panel has a 10 bolt (cover) but I don't think it's original because it has finned brake drums which I don't think they had in '61. I think mine is a "corporate 10 bolt" out of a later truck.
Check this site to match up your cover gasket shape (scroll about half way down), six bolt wheels would mean a truck, not a car, I'd think.
http://coloradok5.com/axleguide.shtml
Larry
Old 04-19-2010, 12:05 AM   #11
Captainfab
60-66 Nut
That CK5 link doesn't show the older 10 bolts.
The '60-'62 C10 trucks had 10 bolt rear ends. They can be identified by the perfectly round rear cover with 10 bolts and a fill plug. Also the third member is removeable from the front of the housing. If you have something different, then it isn't original.
Old 04-19-2010, 11:15 AM   #12
rain_man
rain_man's Avatar
so i think it is this gm 12 bolt
NEED A NEW PROJECT
Old 04-19-2010, 11:16 AM   #13
rain_man
rain_man's Avatar
i just snaped some pics im pretty sure it is the gm 12
NEED A NEW PROJECT
Old 04-19-2010, 12:05 PM   #14
fleetsidelarry
Senior Car Nut
looks like a 12 bolt from possibly a 65-70 (not sure when they first relocated the panhard mount), the location of the panhard bar attachment indicates it definitely isn't a '61, and 71-72 would have had 5 bolts hubs, you said yours were 6. again, I'm not sure when they went back to 6 bolts. Does your frame have an X member?
Larry
Old 04-19-2010, 02:24 PM   #15
rain_man
rain_man's Avatar
i know this is a stupid question but the x member is what??
if it is what i think it is i dont see how it has anything to do with the rear?
if it is what i think it is it is the part the gos in between the front wheels hold every thing together, the engine sits on top of it right??
NEED A NEW PROJECT
Old 04-19-2010, 07:15 PM   #16
fleetsidelarry
Senior Car Nut
no,no, not a stupid question, it's me using the wrong terminology and just confusing the issue, but I don't mean cross member as in a front suspension crossmember or a transmission crossmember, but rather an x frame between the outer frame rails (the 60-62 frames had this, the 63-66 didn't). it does affect the location of the trailing arm mounting pads. its no big deal, certainly doesn't change the fact that you have a 12 bolt, just wondering if the PO had modified the 12 bolt, just forced it to fit (which it apparently will do 'cause some on here have done it), or perhaps you had a later frame (kinda unlikely). I know there's a picture on here somewhere to explain better, I'll see if I can find it.
Again, sorry to confuse the issue.
Your panhard bar (trackbar) has been modified. The earlier bar was longer because it mounted to the axel differently.
Larry
Old 04-19-2010, 07:57 PM   #17
rain_man
rain_man's Avatar
ya the bar looks like it has been spliced into another bar to make it longer.
if anyone has a pic of a 60-63 and then a 456 so i can c the difference thanks.
im wanting to up grade to 5 lug and need to know what to look for
NEED A NEW PROJECT
Old 04-21-2010, 10:14 AM   #18
fleetsidelarry
Senior Car Nut
rain_man, FYI, here's what the 60-62 Frame (with X-member) looks like:
Larry
Old 04-21-2010, 11:20 AM   #19
rain_man
rain_man's Avatar
thanks ill have to crawl under there and take a look
NEED A NEW PROJECT
Old 04-21-2010, 01:16 PM   #20
fleetsidelarry
Senior Car Nut
no need to crawl under if you have the torsion bar front end, it should be this style frame
Larry
Old 04-21-2010, 01:23 PM   #21
Russ65C10
Russ65C10's Avatar
That looks exactly like the 12 bolt in my 65 that I was just painting today.
Russ65C10 is offline   Reply With Quote
