#51 |
Re: Scott's 65 Build Thread
I got the grill painted and put back on today. Also, I set the bed on the frame and none of the cross members line (not even close). So I started another post to ask around about it. With the bed on I can finally see the difference with the 4" drop spirngs. I was told the springs I have in the front are 2". I'm going to cut a 1/2 of a wrap out of the front springs.
#52 |
Keepin it old school
Looking really good man..
Wish I had a house where I could work. Apartment life sucks! |
#53 |
Thanks Bazooka
This is not my house. I own a home, but still don't have this kind of room. The only downside is this place is about a 20 drive each way, but I am blessed that I have a place to this kind of work. |
#54 |
What do you guys think of the stock wheels. They are starting to really grow on me. I'm thinking about having them blasted and painting them flat white or off white, with white walls and replace the trim rings. What do you guys think?
#55 |
I like the idea on the wheels. I can't help on the tire decision because I'm biased; blackwall out is the only choice for me.
#56 |
Did you figure out the bed cross sill problem?
I ran into the same thing on our '66. You probably have cross sills to fit the '60-62 frame. That was our problem and none of the holes lined up. Are the rear most holes too wide to even sit on the frame? Trucks looking good BTW ![]()
![]() ![]() Last edited by joe231; 04-04-2010 at 12:26 PM. |
#57 |
Hey Joe231
No, I haven't figured it out yet, but it sounds like you just did. Yes, the rear brackets are too far apart. The fleetbed was already on the truck when I got it so I don't know the year. I'll let you know what I find. |
#58 |
Cool
if you aren't too concerned about it you could drill new holes in the sills and relocate the rear brackets to fit. If it bothers you, you can replace all the cross sills. Mar-K.com makes new ones that are high quality and made in the USA (Oklahoma city in fact) and they are a vendor here.... ![]()
![]() ![]() Last edited by joe231; 04-04-2010 at 12:46 PM. |
#59 | |||
Wide Eyed User
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 04-05-2010 at 12:14 PM. |
#60 |
Senior Enthusiast
I've always been a fan of stock rims, and I like the original white wheel look, especially with the same color grille and bumpers. Whitewalls would look cool with the color paint you have, but are a pain to clean.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#61 | |
I think that's a good idea...I like the factory steelies with white walls. here's Malibob's 65...
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 Last edited by REDNOSE65; 04-05-2010 at 03:34 PM. |
#62 |
Well, I decided I was going to cut my bed boards myself. I borrowed a table saw and a Rotor table (Thanks Dad and Chris). The wood was a little over $300 from Lowes.
[IMG] ![]() It was very easy to do and it only took a couple of hours (just to cut them out). Installing them in the truck, with the bed on, took an entire day. [IMG] ![]() I also got the body work done on my hood today. This hood was fairly hammered. I would have just tried to find another one if I haven't already paid $75 to have this one media blasted. [IMG] ![]() And FINALLY...it's almost back together. [IMG] ![]() |
#63 |
Just incase you are wondering (and if you didn't see it in the prior picture) why I haven't done the cab yet...I picked up this Big Back Window Cab. It's basically a complete cab. Usual rust spots and the back has been slapped by the bed fairly hard, but I think I can fix it. I plan on leaving my truck assembled while I work on this cab and then do a cab swap. [IMG]
![]() [IMG] ![]() |
#64 |
Resistance is Futile
The bed wood looks really nice!!! Look at all the cool truck parts, can I come over and play???
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#65 |
VA72C10
![]() Join Date: Mar 2008
Looking good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#66 |
You've got some purdy wood
![]() Nice work!
#67 |
One day...
Looks good!!
#68 |
One foot in front of the other
![]() Join Date: Aug 2008
Bed wood looks good- does it have a finish on it?
#69 |
Ok, its been forever since I have posted anything. I am trying to get it done by mid-November so I can join Dino and his Chevy Only Crew (if my truck is acceptable without air bags and laying frame...lol).
#70 |
#71 |
#72 |
Ok, I'm trying once again...[IMG]
#73 |
#74 |
Ok, I quit. I don't understand why it has to be so freaking difficult to post pictures here. GRRRRRRR!!!!!!!
#75 |
