Old 05-15-2003, 09:02 PM   #1
iufan71
CD install on 78 GMC Truck
Just wondering if anyone out there has any advice on installing a non 2-shaft radio in an older gmc? I want to put a new CD player into my 78 GMC,what do i have to cut or not cut,to make the install look good? Any suggestions are appreciated,thanks. Chris
iufan71 is offline   Reply With Quote
Old 05-16-2003, 01:01 AM   #2
78SilveradoSWB
78SilveradoSWB's Avatar
For a clean installation, buy this installation kit (87-99-3052) by Metra Electronics Corporation. It has a radio housing plate that goes between your dash bezel and your dash. It also has a faceplate that goes on the front part of the bezel. Check with your local car stereo store for availability. They go for under $20. I am using a dremel with a thin die grinder disk to enlarge the opening in the dash bezel using the Metra plate as a template. Cut a little smaller as the plastic wants to melt, then file to size. I will also use the die grinder disk to cut the dash also using the template. I am doing this right now, well not exactly, but slowy but surely.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 05-17-2003, 08:49 AM   #3
pkbinplano
pkbinplano
pkbinplano's Avatar
I isntalled a am fm cd player with a wireless remote controll under my driver seat. Works sweet. Just reach under seat to change cd,s. Out of sight and out of mind for frickin thieves. Plus I didn't want to hack my dash up. JMO
http://www.picturetrail.com/gallery/...7496&members=1
84 chevy silverado aka The Bananna Boat
pkbinplano is offline   Reply With Quote
Old 05-17-2003, 07:11 PM   #4
gmc7286chevy
http://www.customautosound.com
has a system called secret audio that hides under the seat.
If you want in dash make sure to make good measurements before you cut the dash.
gmc7286chevy is offline   Reply With Quote
