Old 04-21-2010, 11:18 AM   #1
b00sted
b00sted's Avatar
How do I tell if my truck is
Still 6v or not?
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 04-21-2010, 12:12 PM   #2
Dan Bowles
AD Addict
Re: How do I tell if my truck is
Check a headlight or check the coil. Coils are usually stamped with 12V or 6V right on them. That's the fastest way. Or put a 12V battery in and turn on the headlights. After a few seconds they'll glow at about a million candlepower and then blow if they are 6V. Ask me how I know...
Dan Bowles is offline   Reply With Quote
Old 04-21-2010, 12:13 PM   #3
OrrieG
OrrieG's Avatar
Look at the battery or coil they are usually labeled. If not check the battery voltage with a meter, max on 6v fully charged will be 7v. I haven't seen a six volt battery for a while but I think they just have 3 sets of cells, 12v has 6. Generator and starter might be labeled too.
Old 04-21-2010, 12:42 PM   #4
b00sted
b00sted's Avatar
Well the reason I ask is that the truck does not have headlights or tail lights in it. It does have a 12v battery in the hole but anyone could have stuck that in there.. If it is still 6v I need to change the coil to 12v along with all the lights.... Is there a regulator something I need to add or is that it?
So the ignition switch can stay the factory one? I need to get a new one for it so I just want to make sure...
Old 04-21-2010, 05:00 PM   #5
mylow53
mylow53's Avatar
im pretty sure the regulator has to change (since it regulates the voltage to slightly above 6 volts). all of the external lights, the coil, and the generator all need to be replaced. the starter and mechanical switches of any kind can stay. ingition, starter, headlight switch all are good regardless of voltage. am i missing anything guys?
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 04-21-2010, 06:05 PM   #6
Dragsterbus
Dragsterbus's Avatar
Yep the regulator has to be changed, switchs are ok, don't forget the wiper motor if it's 6 volt,(Vac wipers are ok ha ha) the starter motor will usually be ok , just cranks over a bit faster, i ran a 6 volt starter on a 12 volt car for years and it was fine
Here's the new video of the pro mod body i'm building
http://www.youtube.com/watch?v=obJspWfEttc
http://www.facebook.com/#/pages/The-...9609586?ref=ts
The All Alone, Meet and Greet 2010, Going International. Starting July 3rd. 00:00hrs. where ever it is in the world where you are.. Looking to break the most members online record during the 24hr. marathon.
Please help to promote this event. Edit Signature in your Control Panel to include.....
"All Alone Meet & Greet 2010."
http://67-72chevytrucks.com/vboard/s...d.php?t=393754
Dragsterbus is offline   Reply With Quote
Old 04-21-2010, 06:33 PM   #7
OrrieG
OrrieG's Avatar
stovebolt.com has a tech article on changing 6v to 12 v in AD trucks
Old 04-22-2010, 12:41 AM   #8
solidaxel
solidaxel's Avatar
Don't forget the sending unit in the gas tank !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-22-2010, 07:14 AM   #9
Dan Bowles
AD Addict
Is it the sending unit or is it the gauge? I've always heard it was the gauge but I guess basic V=IR should tell me the sending unit may need the love...
Old 04-22-2010, 07:15 AM   #10
Dan Bowles
AD Addict
It should start and run with a 6V regulator but it won't charge. Regulator will cut it down to no more than about 8V charging. If you crank it all the way up, 9V.
Old 04-22-2010, 01:34 PM   #11
OrrieG
OrrieG's Avatar
here is the link to the stovebolt how to convert
http://www.stovebolt.com/techtips/12...onversion.html
