Old 04-21-2010, 11:11 PM   #1
kev2809
low n' slo
kev2809's Avatar
Need some part number help here
well, i tore apart my front suspension today to make way for some new stuff. i want to get a lot of this done now so i dont have to take it apart again.
i want to get new calipers, rotors, and brake pads. i called o reilly and they said a 67 (which is what i have) didnt have disc brakes up front, it only shows drums. he said he checked his book and nothing in our year range came up for disc brakes, i was thinking maybe its from another year but i know at some point during 67-72 there was disc brakes lol . so, can someone help me out with a part number for these rotors and calipers?
also, when i pulled off my spindle today, i noticed when it took the rotors off that they have a bearing in the middle. if i bought new rotors, do they come with this bearing?
im just looking for basic replacement parts, no performance or upgrade stuff needed here
thanks for any help!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 04-22-2010, 12:16 AM   #2
SCOTI
SCOTI's Avatar
Re: Need some part number help here
Discs started in 71. You need to purchase the parts that are the correct match for the spindles you plan to use (71-72 or 73-87 spindles). The rotors use inner & outer bearings. The inner bearing is retained w/a seal which is what you prob are referring to.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-22-2010, 06:33 AM   #3
kev2809
low n' slo
kev2809's Avatar
ok. when I bought my spindles I ordered them for a 67, so I guess I need to order a 71-72 rotor. so for the calipers, I would ask for 71-72?
-_--_--_ _________
Old 04-22-2010, 08:46 AM   #4
SCOTI
SCOTI's Avatar
I would only be guessing as well.
I ordered spindles for my 68.... they were for a 73-87. Are the spindles you bought supposed to be a 'direct swap' allowing you to re-use your tie-rods & BJ's? I purchased 73-87 parts for mine because I confirmed w/the manufacturer that's what they needed.
Regardless, I'm fairly confident the calipers were the same from 71-87 (HD 1.25" version). The rotors might have different p/n's though but as long as you get the correct rotor for the spindle you should be good (1.25 or 1").
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-22-2010, 09:16 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
You can order 71-72 calipers,... but the 73-87 (HD 1.25") calipers are cheaper.
What brand of spindles do you have?
Keith
Convert to disc brakes.
Old 04-22-2010, 11:02 AM   #6
kev2809
low n' slo
kev2809's Avatar
well the part number I found myself is 81-60258 from o reilly for the rotors.
I ordered my spindles from cpp..for a 67.
and the balljoints I already pressed in were 67-70 in my 70 lca's. so the spindle should be right for my lca and uca..
-_--_--_ _________
Old 04-22-2010, 11:04 AM   #7
kev2809
low n' slo
kev2809's Avatar
-_--_--_ _________
Old 04-22-2010, 11:48 AM   #8
POPO1984
POPO1984's Avatar
so will the 73 -87 calipers fit on a 72 drop spindle
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 04-22-2010, 05:20 PM   #9
lolife99
lolife99's Avatar
yes.
I have a set on my '69.
Keith
Old 04-22-2010, 06:36 PM   #10
kev2809
low n' slo
kev2809's Avatar
sooo...
what your saying i can get is..
71 rotors, 73+ calipers, on my 67 spindle and balljoints?
let me make a quick list of part numbers so i can be a 100% right when i go get my stuff!
-_--_--_ _________
Old 04-22-2010, 06:45 PM   #11
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I created a spreadsheet for front end rebuild awhile back, here it is if it helps. I do need to add Caliper part number though.
http://www.2heeldrive.com/Chevrolet/...onent_info.xls
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 04-22-2010, 07:07 PM   #12
kev2809
low n' slo
kev2809's Avatar
71 rotors, pn 81-60258 - 29.99 each
73+ calipers, pn 18-4035 (R), 18-4036 (L) - 11.99 each
67 upper balljoint, pn K6024 - 14.99 each
67 lower balljoint, pn K6023 - 14.99 each (already installed)
and these are all house brand...
does this look about right?
-_--_--_ _________
Old 04-22-2010, 07:08 PM   #13
kev2809
low n' slo
kev2809's Avatar
man, i need to install a key for microsoft office, i cant look at it lol
-_--_--_ _________
Old 04-22-2010, 07:43 PM   #14
lolife99
lolife99's Avatar
You can even use the 73-87 HD rotors if you want. They are cheaper also.
Just make sure to get 1.25" rotors and calipers for 1.25" wide rotors.
I just tell the parts guy that I'm working on a '73 truck. Makes it easier for everyone.
Keith
Old 04-22-2010, 08:03 PM   #15
SCOTI
SCOTI's Avatar
Whatever you do, don't tell them you have spindles for a 67.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-22-2010, 08:22 PM   #16
kev2809
low n' slo
kev2809's Avatar
haha...you guys couldnt be more right! i went through that when i was getting balljoints.
i didnt know 67-72 and 73+ suspension was that interchangeable.
well, i guess ill be getting 73+ rotors and calipers. thanks for the help fellas
*edit*
which brake hose (that runs to the caliper) do i get?
the 67 and the 73 hoses look totally different, and the 67 one is half the price. 10.99 compared to 19.99
-_--_--_ _________
Old 04-22-2010, 09:47 PM   #17
lolife99
lolife99's Avatar
You need either 71-72 hoses or 73-87 (cheaper, but longer) hoses.
The longer 73+ hoses work good with bagged trucks.
Keith
Old 04-22-2010, 10:19 PM   #18
kev2809
low n' slo
kev2809's Avatar
hmm, will the 73+ hose fit my 67 truck? the ends of the hoses look different than the 67. im pretty sure they will fit the caliper since it will be a 73+ also...
maybe im lookin at the wrong part on oreillyauto.com
-_--_--_ _________
Old 04-22-2010, 10:23 PM   #19
SCOTI
SCOTI's Avatar
I used post-73 rubber lines w/post-73 hard lines on my 68 & plan to do the same w/my 64. The 73 rubber lines should also work well w/the pre-73 hard line set-up as lolife mentioned because they're slightly longer.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-23-2010, 12:44 PM   #20
Twisted78SS
Wide n'Low
For anyone who does not have Excel, I uploaded the current version of the spreadsheet to Google Docs here - http://spreadsheets.google.com/ccc?k...FNk9IeXc&hl=en
I will keep adding info as I get it.
Air Force Retired
Old 04-23-2010, 04:02 PM   #21
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Sort of. The 73-87 hoses would work with 71-72 hard lines, but not 63-70 hard lines. If you will remember, 63-70 trucks used hard lines that run off the back side of the crossmember. There would be way too much hose length.
Now, 71-72 ran the hard lines across the front of the crossmember to tabs near the edge. The 73-87 hoses would likely be close enough in length to work. But, if running 71-72 hard lines, I like to buy 71-72 dually 1 ton front hoses. I get them from Kennys Trucks. The dually hoses are the exact same as 1/2 ton hoses but longer in length by an inch or so. That gives needed slack when the truck is lowered.
By far, the easiest way is to rob 73-87 hard lines front to back and use 73-87 hoses. The holes were even in the frame of my 63 truck for them. All I had to do was lay the 80 model lines in place and bolt them down. No mods needed at all. Then I run an 80 model master cylinder too so there was no fabrication or modification of the hard lines needed. I used all three replacement 73-87 brake hoses, even the back one worked perfect.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-23-2010, 11:11 PM   #22
SCOTI
SCOTI's Avatar
I've done multiple trucks this way. My current 'Dropmembered' 64 will use them as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-29-2010, 08:25 PM   #23
kev2809
low n' slo
kev2809's Avatar
hey, i think i will just go 73+ for everything. with that being said about the hard lines, does the 73+ suburban bolt right up to my 67?
i know you said it does for the trucks, but i forgot to mention mine is a suburban
-_--_--_ _________
Old 04-29-2010, 08:37 PM   #24
SCOTI
SCOTI's Avatar
There's no difference in the firewalls or front rails (burbs vs. trucks) so I wouldn't think there will be any issues.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-29-2010, 08:45 PM   #25
kev2809
low n' slo
kev2809's Avatar
what about the brake lines to the rear? or is this something totally different? i just assumed you guys were talking 73+ hard lines all the way to the back.
so its 73+ up front, then original hard lines to the rear?
-_--_--_ _________
