Old 04-22-2010, 09:33 AM   #1
Quackaddict
"Hooked on Quack"
A/C question
Yet another question in the line of trying to decide if I want to use used parts or spending the extra $$$ for new. Found a donor truck that had factory A/C. All the parts are there from controls to compressor. My truck is not an A/C so I don't have any of the vents and I don't know if those can be pulled.
The plus side is this system is 1/3 of the price a vintage air unit. I know I will need some parts but it seems like a solid system to start with.
Anyone made this conversion of a stock A/C system into a non A/C truck?
Quackaddict is offline   Reply With Quote
Old 04-22-2010, 10:08 AM   #2
19stepSide72
wanna be 67
19stepSide72's Avatar
Re: A/C question
change out your dash, cut along the dash pad holes, two bolts and replace with a/c dash. Now you have a a/c truck.
19stepSide72 is offline   Reply With Quote
Old 04-22-2010, 12:32 PM   #3
mrein3
mrein3's Avatar
Re: A/C question
The firewall is different too.
I modded mine. It isn't impossible but you do need to weld in some metal and cut some other away.
I purchased an AC dash intending to do like 19stepSide72 said but I eventually just used it for a template to cut holes in my current dash.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-22-2010, 05:53 PM   #4
Rat Bastid
Rat Bastid's Avatar
Re: A/C question
Swap cabs
Rat Bastid is offline   Reply With Quote
Old 04-22-2010, 06:05 PM   #5
gkesseru
gkesseru's Avatar
Re: A/C question
You can get louvers that mount under or through your dash.
see
http://www.oldairproducts.com/catalo...0000_120132055
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 04-22-2010, 07:20 PM   #6
Dark Knight
Dark Knight's Avatar
Re: A/C question
You don't HAVE to modify the firewall. I just set the box in place and drilled new holes. A/C and heat work just fine. Old air or Vintage air has the templates to cut new holes that you can print out.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 04-22-2010, 10:11 PM   #7
Quackaddict
"Hooked on Quack"
Re: A/C question
awsome thanks!!
Old 04-23-2010, 12:22 AM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: A/C question
I did it the hard way I guess but the cheapest I guess to. I bought a junk AC truck and swaped it all over to my truck. I cut the holes and mounted everything myself.
http://my.att.net/p/s/community.dll?...eid=298462&ck=
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
