Old 04-22-2010, 11:21 AM   #1
Street Sweeper
Street Sweeper's Avatar
Inline 6 Intake / Exhaust Question
I posted this question on the engine page - thought I might get more input if I posted here as well . . .
I've got a '65 suburban with a 230 L6. I'm ignorant on these motors - I admit that up front.
On an inline 6 (194/230/292) the intake and exhaust manifolds are bolted together. If I wanted to make an exhaust change (headers, etc.) without the expense of replacing intake and carb at the same time - is it possible? Can you run stock intake / aftermarket exhaust or vice-versa?
If so, what would I need to do to make it work?
Thanks for your help. I apologize up front for my lack of knowledge on all things L6.
Street Sweeper is offline   Reply With Quote
Old 04-22-2010, 01:42 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Inline 6 Intake / Exhaust Question
Yes, all of the stock intakes are bolted together with three bolts. You can swap intakes and exhausts back and forth. Different brands of manifolds might require headers though.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-22-2010, 03:02 PM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
Yes, I did this a LONG time ago. I put on a Headman header and kept the stock intake and 1 bbl carb. The headers came with everything that I needed except for the exhaust tubing from the reducer to the mufflers and tailpipes.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-22-2010, 03:35 PM   #4
11echo
I was thinking of this this myself! I was looking at these headers:
http://www.summitracing.com/parts/BIG-11510FLT/
11echo is offline   Reply With Quote
Old 04-22-2010, 04:49 PM   #5
Street Sweeper
Thanks for the link - I had been looking at Hedman headers form LMC. I like the price of Summit's better.
Now I've just got to decide if this old 6 cylinder is worth the effort.
Old 04-22-2010, 04:50 PM   #6
Street Sweeper
Thanks Aggie91 - that's just what i needed to know - whether or not it was possible.
Old 04-22-2010, 05:45 PM   #7
Prerunner1982
Prerunner1982's Avatar
Clifford Performance also offers 6 cylinder stuff.
http://www.cliffordperformance.net/M...gory_Code=C250
My Father used some of their stuff in his Jeep CJ7 many years ago.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-22-2010, 05:46 PM   #8
11echo
Left Field ...Have you thought about putting in a HEI distrubitor in? I just did, BIG DIFFERENCES!!!
Old 04-22-2010, 06:17 PM   #9
Shaky
Six in a row makes it go...
Shaky's Avatar
Clifford stuff:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-22-2010, 07:50 PM   #10
aggie91
aggie91's Avatar
That is just like the Headman headers I used.
Definitely do this, major improvment.
This shorty head was not offered back when I did mine. I would have rather had them...
Karl
The LST Challenge:
Old 04-22-2010, 08:18 PM   #11
hb32
hb32's Avatar
I bolted a set of Langdons cast iron headers on my 65 with a 230 a month ago. Next is an Offy single quad as soon as I come up with a carb. I was planning on a Holley 390 cfm but have decided to look for an older Rochester 4 jet which should bolt on without an adaptor plus look a little more period correct.
Life is too short to drive a boring vehicle.
hb32 is offline   Reply With Quote
Old 04-22-2010, 08:22 PM   #12
hb32
hb32's Avatar
I went with the Pertronix and not sure if it is a major improvement but seems to run better.
Old 04-22-2010, 08:33 PM   #13
78 Chevyrado
I like those iron headers! They look slick! and so different
78 Chevyrado is offline   Reply With Quote
Old 04-22-2010, 10:09 PM   #14
66coffin
66coffin's Avatar
i'm gunna run those cast iron ones on my 292 from Langdon's, i've heard good things about his stuff. check out his site langdonsstovebolts.com and listen to the sound clip he has of his split manifold sixer, it sounds awesome!!
'66 c10ish straight 292 power!
66coffin is offline   Reply With Quote
Old 04-22-2010, 10:21 PM   #15
Street Sweeper
Thanks for all the info - I knew I was coming to the right place.
hb32 - FYI - '68OrangeSunshine posted his set-up over on my post in the engine section. Here's what he did for a classic looking carb;
"an Edelbrock 1404 500 CFM 4Bbl [clone of the Carter AFB] on an Offy intake and Clifford long tube headers."
11echo - I was considering HEI - good to hear from some folks who have already done it.
thanks again everybody - this helps a great deal. It's nice to get some answers without having to take everything apart first.
Old 04-22-2010, 10:22 PM   #16
hb32
hb32's Avatar
Here is how it sounds
Old 04-23-2010, 01:11 AM   #17
Vernski
Hey Shaky what carb are you using on your Clifford? I used a Edelbrock 1404 manual chock and have been happy with it. Just a note if your going to lower your truck or bag it the long headers are not the best idea, with short headers you can run the pipes through the frame just something to think about...Vernski
Vernski is offline   Reply With Quote
Old 04-23-2010, 05:49 PM   #18
Shaky
Shaky's Avatar
It's a Holley 390 with manual choke.
Old 04-23-2010, 05:52 PM   #19
Shaky
Shaky's Avatar
Here's what a stock intake and exhaust manifold look like. You can see that they're two pieces and that you can change out one or the other:
Old 04-23-2010, 06:15 PM   #20
hb32
hb32's Avatar
Any issues with the carb north/south and how does it run with the 390?
Old 04-24-2010, 07:34 AM   #21
Shaky
Shaky's Avatar
No north/south issues. It took awhile messing with jets and power valves and springs to get it working right since it was probably set-up for a V8 out of the box. It pulled strong when the secondaries opened up and it was up on the cam.
