Old 04-03-2010, 10:32 AM   #476
Keith Seymore
Keith Seymore's Avatar
Re: Intro from an old Assembly Plant guy
Thanks, Longhair!
(lol) -
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-03-2010, 11:22 AM   #477
3r!c84
Badass
3r!c84's Avatar
How did you do that!?!!?!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 04-03-2010, 01:16 PM   #478
Keith Seymore
It's on a different thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=388141
1979-1986
1986 - 2019
Old 04-17-2010, 09:51 PM   #479
scruffre
scruffre's Avatar
Hey Keith, just wondering whats involved in removing the shifter? I'm putting the same trans in my Blazer 4X4. Thanks
Dave
scruffre is offline   Reply With Quote
Old 04-18-2010, 08:21 AM   #480
Keith Seymore
Cool set up!
The shift lever is designed with some little spring clips to retain it into the shifter base - so going together is easy, because you just push it in and seat it.
Coming out is a little tougher, because you have to get down in there and "trip" those retaining tabs.
I used a couple of small pieces of thin aluminum, but you could use anything thin and fairly strong, like a steel six inch scale. Stick it down beside the shift lever and the base, one on each side, and give the shifter a good pull.
If everything works right it should come right out!
Let me know how you do.
K
1979-1986
1986 - 2019
Old 04-21-2010, 03:55 PM   #481
waltharper
waltharper's Avatar
Originally Posted by Keith Seymore View Post
We've owned about a half dozen of these little trucks, including a '69 GMC stepside, a '75 fleetside, an '80, an '82 and this one (all 2wd shortboxes).
As I mentioned, here is my latest project:
(New):
This is my '87 Chevy pickup, of which I am the original owner. In fact, I ordered this truck and followed it down the assembly line as it was being built. It was coming down out of paint and into the trim area at the beginning of second shift. I picked it up there and followed the body through trim with no issues. When the cab and box were complete, I hopped downstairs to the engine line and followed it through the process (we changed out the oil filter and fixed a cross threaded dust cover bolt). By then the chassis had started on the rivet line; I followed the chassis, then the engine/chassis assembly down to body drop. Once the cab and box were set it's a straight shot down the final line to the end. During roll test the inspector wrote up an A/C charge (which I bought off on) and that the backup lights were not working. The lights were repaired on the "short line" repair line, after which I drove the truck myself off the line and over to the shipping building. I told "Lloyd" that this was my personal truck, left the plant at 1 am and by 5 pm that same day it was at Hank Graff Chevrolet in Davison, Michigan.
I owned this truck for two years in Michigan and then two years in Arizona. By then I had been promoted to a GM Company Vehicle driver and, not having need of this truck, sold it to my father - in - law. He owned the truck, in Arizona and Montana, until his passing last August (of 2008). Having bequeathed it to me, it's now back, cosmetically a little worse for wear but in great shape mechanically.
So that makes me both the original and third owner of this truck (lol).
Here it is today:
I've already got some of the parts on order to fix it back up, starting with the interior (the seat's already been redone). I hope to get it repainted over the GM shutdown period in July and then I intend to drive it.
K
if this was a 1979, you would be talking the same truck as mine. including the dirt and dents and bed.
you being the man to talk to about trucks, I ma running a 4 speed with granny low. what other top loader could I put in to shift a little smoother. it is bolted to a 250.
Also I am looking for a power steering for the truck, engine has intregrated intake to the head, how hard is it going to be to find brackets and parts to do this? I know go to a salvage yard. Around here there is "no" trucks of this time frame in the yards. I may have to travel to find a yard.
waltharper is offline   Reply With Quote
Old 04-22-2010, 01:28 PM   #482
Keith Seymore
Thanks; I got your PM and responded in great detail there....
Good luck with your project!
BTW - I should mention I did my entire restoration in the driveway; this truck has never been inside my garage (hopefully that is an encouragement to you).
K
1979-1986
1986 - 2019
Old 04-22-2010, 10:59 PM   #483
USSkoval
That's something I don't remember seeing before. What tranny model would that be?
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 04-23-2010, 12:14 AM   #484
85chevylwb
welcome keith, glad to have you aboard, guys if you will notice the link that bigblock posted on page 1, keith narrated the photos. def an assest to us all!!
85chevylwb is offline   Reply With Quote
Old 04-23-2010, 07:44 AM   #485
Keith Seymore
That would be the RPO MY6 4 speed manual (overdrive) trans. It's actually a New Process A833, but with 3rd gear set to 1:1 and 4th gear as a .73 overdrive.
Nice trans! It uses ATF instead of gear lube, so its smooth and easy shifting, even in cold weather.
Thanks, 85ChevyLWB!
K
1979-1986
1986 - 2019
Old 04-23-2010, 10:07 PM   #486
scruffre
scruffre's Avatar
Thanks, 85ChevyLWB!
K
Thanks Keith. I was going to ask the same question.
The transplant happens this weekend.
I must remember to take pictures LOL
Dave
Old 04-24-2010, 03:50 PM   #487
Keith Seymore
Prom Time:
Not really "truck" related, but it's that time of year; I suspect dads all across America are being asked to drive their kids around "in an old car", and my house was no exception.
Last night was my turn - took the kids for a ride and then dropped my second oldest daughter at her Senior Prom. We managed to get a few (silly) shots amidst all the seriousness:
1979-1986
1986 - 2019
Old 04-24-2010, 09:43 PM   #488
electrician42
electrician42's Avatar
great pictures keith ... will be precious memories for you both some day .. brings back memories of my daughters prom nights.......and i just remembered my senior prom ride was a 69 chevy caprice .. 396 th400 ... it was a sweet ride and that was in 85 ....
2011 silverado 2500hd ext. cab 6.0
2007 tahoe lt
2004 harley-davidson superglide
1982 chevrolet c10 stepside 2 wheeldrive..current project
electrician42 is offline   Reply With Quote
Old 04-24-2010, 09:48 PM   #489
3r!c84
Badass
3r!c84's Avatar
i remember my prom night.(last month) lol pulled up in my truck with open headers me and my girl gets out.what a entrance
the valet guy didnt want to drive my truck so i parked it upfront
-00 Saturn 5spd
1/4:13:90
Old 04-25-2010, 12:24 AM   #490
Ben IV
Truck is looking great, was your chevelle in popular hotrodding recently? looks very familiar.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 04-25-2010, 01:24 AM   #491
SBTork
Garage wrench
SBTork's Avatar
classy
Good stuff Keith.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 04-25-2010, 07:50 AM   #492
D13
D13's Avatar
Love the truck!
I love what you've done to the truck. To avoid thread clutter I sent you a PM about a couple of items.
My favorite trucks have all been 6 banger manual heater only rubber floors.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 04-26-2010, 07:26 AM   #493
Keith Seymore
Yes, thanks for noticing.
There was a thread here somewhere (...hmm...let me look....here it is: http://67-72chevytrucks.com/vboard/s...d.php?t=355677 - includes some "behind the scenes" shots) and it can also be viewed on their website: http://www.popularhotrodding.com/fea...lle/index.html
K
1979-1986
1986 - 2019
Old 04-26-2010, 07:27 AM   #494
Keith Seymore
Re: Love the truck!
Thanks, I saw that. I'll reply in a minute -
K
1979-1986
1986 - 2019
Old 05-07-2010, 11:41 AM   #495
scruffre
scruffre's Avatar
Hey Keith
Your instructions for taking the shifter out worked perfectly. I got everything changed over rather painlessly
Here's a link to the progress http://67-72chevytrucks.com/vboard/s...=1#post3962721
Dave
Old 05-07-2010, 02:53 PM   #496
Keith Seymore
Glad to be able to help; lookin' good, btw.
K
1979-1986
1986 - 2019
Old 05-07-2010, 02:54 PM   #497
Keith Seymore
Just noticed: one year ago tomorrow since I joined the site!
1979-1986
1986 - 2019
Old 05-08-2010, 07:09 PM   #498
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
happy birthday? ForumDay? any congrats btw Truck looks really good.
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 05-15-2010, 05:17 PM   #499
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Wow Mr. Seymore.. thats cool that you have soo much knowledge on these chevy's... Do you think that these year trucks.. 73-87.. are arguably the best years for fit and finish that GM ever made?? Also... Didnt GM figure the cabs were a bit tight.. behind te driver's side.. for big guys?.. LOL Im 6 foot 230. luv my truck.. thank God I have tilt!
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 05-29-2010, 09:48 PM   #500
Keith Seymore
This is something I've been wanting to do for quite some time now; ever since I found the old tow bar hanging on the wall at Mom & Dad's house.
I put a hitch on the Grand Prix over the winter and finally got to try it out today -
That's how we used to roll, back in the day!
1979-1986
1986 - 2019
