Old 05-16-2003, 05:06 AM   #26
SEVEND2
SEVEND2's Avatar
20/50 with Fram profilters year round, i dont change oil type grades
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 05-16-2003, 06:50 AM   #27
ZOOMY
oil
Any filter except ones made by fram. !!!!... Pennzoil & weight depends on the weather, miles on the engine & how hard I'm pounding it; 5w30 (january 20 below) 10w30 normal winter, 10w40 summer, 20w50 pounding it do death (towing summer)..............Zoomy
ZOOMY is offline   Reply With Quote
Old 05-16-2003, 09:01 AM   #28
meathead95
computer illiterate
meathead95's Avatar
I use 10w30 penzoil and fram filters. when I got my 90 jimmy it had a bad head gasket from overheating the engine, granted it had close to 200,000 miles on it. but anyway my buddy bought it new and used quaker state oil the whole time. and when I pulled the intake and valve covers you couldnt see the pushrods or rocker arms they had so much gunk built up around them. I had to chip it away with a screwdriver and suck it out with the shop vac. so I swear never to use quaker state oil in anything.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 05-16-2003, 10:09 AM   #29
Mike Culpepper
Red
Mike Culpepper's Avatar
The same thing happened to my '89 Silverado w 175K miles, the gunk was so bad it clogged the PCV system causing the rear main to blow(that's what a mechanic friend told me). No mor Quaker state fo me.
Mike
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
Old 05-16-2003, 10:11 AM   #30
Project1970
14.1 @ 96MPH
Project1970's Avatar
LOL...look at the date of my previous post in this thread...this one was started over a year ago!
Now I'm using Mobil 20w50. Maxlife was doing nothing other than hurting my wallet.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-16-2003, 05:54 PM   #31
Linus0014
Guest
Posts: n/a
LOL, that is pretty funny. But I have a question. My engine is a crate w/ 40,000 or so miles. I replaced the oil pump and started to use 20/50 b/c its sooooooooo damn hot here. its 97* outside right now. And ever since then, when driving my oil pressure is almost maxed out, but when I drive its about 1/2 or little more. I heard either it might be too thick of oil or something else. Anyone have any help?
Old 05-16-2003, 08:30 PM   #32
Project1970
14.1 @ 96MPH
20w50 is certainly awfully thick for a relatively new engine. 10w30 would be just fine, or maybe 10w40. But 20w50 is a lot unless you're dealing with an engine with at least 100,000mi more miles than that (like my 134,000 mile 350 with 33 year old rings!)
Old 05-16-2003, 11:54 PM   #33
68CST327
20w50 Pennzoil w/ Fram (unfortunately) filters. I only use them because I can't find any other brand around here, and I'm too lazy to order Wix or AC.
I use 10w40 in the Cadillac engines; '81 w/ 368 and '90 w/4.5L.
I think Oil brands are like car brand loyalty; I've always used Pennzoil because my parents swore by Pennzoil, and they used it because their mechanic(s) always used it. My grandfather always used it, and that's why I think my mom got me to use Pennzoil.
68CST327 is offline   Reply With Quote
Old 05-17-2003, 01:06 AM   #34
Blue68
Blue68's Avatar
Pennzoil 10w30 in all my cars and my honda lawn mower.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 05-17-2003, 02:34 PM   #35
Linus0014
Guest
Posts: n/a
68 cst, where are you from?
Old 05-17-2003, 08:11 PM   #36
BubbaGreen
Might as well add my 2cents worth of opinion...
I am a believer in synthetics, but only if the engine has been
introduced to them with less than 30k or so and using the
factory recommended weight, ie, 10W-30. I have taken a few
engines apart with 100k+ miles.....seems like the worst sludge
in engines ran penzoil and quakerstate oils. I ran valvoline
10W-30 Turbo formula in a turbo charged car I own....blown head
gasket at 55k, the top half of the engine was still extremely
clean. Synthetics will find leaks in an engine quickly and I dont
recommend switching back and forth. For the most part, syn oil
will prevent alot of gum and sludge build up due to excessive heat. Allow longer run times, sometimes beyond the recommended
filter changes. I myself like both Mobil_1 and K&N oil filters, mainly due to the fact that they use synthetic filter media and not paper.
But in the end, it's what ever makes one happy, everyone has there opinions...
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
