Rear end / transmission performance shops near Snohomish?
Hi,
Like the title says, I need to find a shop or two that does performance rebuild work. Anyone have any experiences in this part of the coutry? |
Re: Rear end / transmission performance shops near Snohomish?
I've heard good things (and have had good experience) about Snohomish Transmission in Monroe...they are right around the corner from where I work. They rebuilt a 700R4 for a friend of mine and he had a few issues with it afterwards and they took care of him. The only work I've had done there was on a manual tranny...they installed new bearings on an SM-465 I had. All of my neighbors told me to go there when I was looking for a shop.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
69 Fleetside
![]() Join Date: Mar 2009
I just ordered a new th350 from Jegs - it was cheaper than a rebuild to hold 400+hp
If you have anything other then that though(th400/200r4/700r4), it will be cheaper to rebuild... For the rear end try Randy's Ring and Pinion - they are 'the' place to take it, but aren't cheap... Last edited by Beatcoaster; 04-23-2010 at 10:06 PM. |
Hey - just now getting back to this thread. Thanks for the feedback
Randy's ring and pinion sounds like someplace I need to stop and talk - have yet to find anyone over on the eastside (where I work) who does more than factory style stock rebuilds. May also check out that transmission shop in monroe - though not sure they do custom or hotrod style work. I kicked the idea around - buying a new one that is. Already buying that 383 stroker from Jegs, may as well look a little closer at my other costs and see what the bottom line is. Lots to be said for a fresh purpose-built transmission. Last edited by sizzle-fry; 04-28-2010 at 10:56 AM. |
69 Fleetside
Lots to be said for a fresh purpose-built transmission. <--- agreed, that was the route I decided on after pondering it for months.
I got the 405hp/440ft-lb Blueprint 383 from Jegs, Jegs TH350 with a 2300stall, and my stock driveline rebuilt and beefed up by Drivelines NW with a new yoke/u-joints/etc...my rear end is the weak link at this point but will have to make it for a year or so until I swap the gears to 3.42, add a limited slip diff, and swap to Moser 5 lug axles - hopefully it will be fine if I just baby it a bit. My truck should be rolling for the first time in 1.5 years. Here is a pic of the 383 for ya! ![]() ![]() |
Thats the one alrighty - the blueprint 383 stroker. Sounds like you have done alot of the things I'll have to be doing. Drivelines NW is on my list already - will be all over 'em once I finish blasing/painting the chassis and begin reassembly. I like your installation, curious which headers you chose... Congrats - nice to get the machine back on the road
I'm working on a 68 C20 thats been designated for towing duties. I'll need to stick with my 8 lug setup but I know exactly zero about chevy rear ends, etc. Now I'll spend the next few hours reading through Jegs cat online... my boss thanks you =) Last edited by sizzle-fry; 04-28-2010 at 11:24 AM. |
69 Fleetside
They are the long tube Hedman headers, but I would not use them again if I had to, or recommend them. The plug for #5 is nearly impossbile to get in/out, they hit the brake line on the passenger side, so I had to reroute it, and they touch the driver side lower control arm so you have to bang in one of the tubes slightly and get a 90 degree zirc fitting for the arm. I don't know what would be better to use to avoid this, and keep the long tubes, but these were a nightmare. It's not fun when you spend $300 on coated headers that will supposedly fit with no issues, only to spend more money and hours upon hours of time rerouting/bending brake lines and then essentially ruin them, just so they will fit...but they do sound good!
![]() Last edited by Beatcoaster; 04-28-2010 at 12:18 PM. |
#8 | |
Give Ellis at speed secrets a call. He did my 700r4 rebuild for me. I believe he did work for snohomish transmission, but it out on his own now. Great Guy. Let him know I sent you.
http://www.ssefi.com/#Home |
69 Fleetside
5 minutes from my house, badass, I wonder if they can help tune my carb and fuel/air mixture once I get this thing rolling?!
BTW - thanks all for the contributions here. I'm pretty sure that:
Driveline goes to drivelines NW - had 6 different folks extoll their virtues, they also seemed ready to go to work when I spoke with em. RearEnd is Randy's - got lots of good info and education from em. Will have 450 torque and a large towing load... I dont mind making a little spend here. The work is easy enough, just tedious and stinky. Trans - sheesh Beatcoaster is right - 795 for a new th400, drop in, clean n bright, and built crisper than stock. Even with shipping it seems better than paying 800 for a rebuild(would use Monroe's shop for this if I did it, they were ready to roll and understood what I wanted). Jegs it is, will order the th400 the same time I order that 383 stroker motor. Its gonna take a month or two (lol)for the big spend, starting with driveline and rearend. I still have to media blast, repair, prime/paint the chassis and rebuild the front end before the motor/trans anyway. Good to have ducks in a row first, thanks again. Last edited by sizzle-fry; 04-30-2010 at 10:46 AM. |
