Old 04-23-2010, 03:47 PM   #1
vyrus
axle seals 83 chev k10 4x4
good day all can someone tell me if the axle seals are inner on my truck and if so a breakdown on how to change them out. also just changed trans seals and still leaking there was this rubber washer thing that looked like a gear would that be the reason for it still leaking any help would be good thanks
vyrus is offline   Reply With Quote
Old 04-23-2010, 04:03 PM   #2
Turbo85GMC
Turbo85GMC's Avatar
Re: axle seals 83 chev k10 4x4
On the rear:
  1. Pull off the wheel.
  2. Pull off the brake drum.
  3. Drain oil from differential.
  4. Take off diff cover.
  5. Take out bolt that holds in center pin.
  6. Take out center pin.
  7. Go back to the axle where you took the drum off.
  8. Push the axle in.
  9. Go back to the diff.
  10. Reach in and take the "C" clip off the axle.
  11. Go back to the axle where you took the drum off.
  12. Pull the axle all the way out.
  13. Now you can see the seal.
  14. Pry out the seal with a big screwdriver or vice grips.
  15. Tap new seal in with a hammer and big socket.
  16. Reassemble in reverse order.
  17. Do other side.
  18. Don't forget to put new oil in the diff.
  19. Drive it like you stole it!
Don't know about the front, mine's a 2wd so it's completely different.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 04-23-2010, 04:25 PM   #3
vyrus
my bad I should have said what axle (front)
Old 04-23-2010, 05:16 PM   #4
LONGHAIR
The inner axle seals on the front axle require a complete tear-down of the entire axle. The only thing left is the pinion...drive shaft removal is not necessary either.
The seals are removed from inside the differential cover after the carrier is removed. This of course means that the axles have to come out too, thus requiring hub/rotor and spindle removal too. It is a rather complex thing for such a simple little seal....and it gets you into a few "while you are in there" jobs too. The axle joints should be replaced, wheel bearings re-packed, wheel seals replaced, and I would take a good look at the ball-joints....."while you are in there".
You will probably find that removing the spindles will be the hardest part of this process.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
