Old 04-23-2010, 05:02 PM   #1
lowsled71
lowsled71's Avatar
need help with a 71 4X4
I need help i have a 71 1/2ton 4x4 the problem is that the axle joint is broke and i want to know if you can use late model frontend parts in this frontend? heres a pic to show whats broke.. I have a couple frontends out of 1/2ton trucks in the years of 73 to 87.
'69 Suburban 2wd (on hold)
'71 Chevy C-10 2wd lwb have a pair of them(on hold)
'63 Chevy C-10 4wd on a '78 blazer frame
'71 Chevy C-10 4x4 4 inch with 33's
'68 Chevy C-10 2wd lwb
'03 Chevy Crew Cab 4X4 Duramax (DD)
lowsled71 is offline   Reply With Quote
Old 04-24-2010, 11:11 AM   #2
pumpkin
pumpkin's Avatar
Re: need help with a 71 4X4
The inner axle will have to be for the dana 44, but the outer can come from a dana 44 or a ten bolt.
pumpkin is offline   Reply With Quote
Old 04-25-2010, 01:31 PM   #3
lowsled71
lowsled71's Avatar
so that axle is a dana 44?
Old 04-25-2010, 08:19 PM   #4
Yes.
Old 04-28-2010, 08:36 AM   #5
msgross
msgross's Avatar
correct statement... I found this out when I did my swap... If you have other axles then you could also just swap the entire axle, really just depends on how good the compenents are (brakes, gears, u-joints etc..)
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
