Old 05-16-2003, 03:37 PM   #1
guyryan100
guyryan100's Avatar
Bearings cleaned?
I was replacing a lug stud on the front end and managed to drop the greasy bearing assembly right into the dirt.
How can I clean it? Could I just use gasoline or should I use something different due to the proximity to the break drums?
guyryan100 is offline   Reply With Quote
Old 05-16-2003, 03:46 PM   #2
COBALT
COBALT's Avatar
NO. Don't use gasoline on anything unless you absolutely have to. I've seen some bad things happen, man. Bad things.
Get some Brake Cleaner from NAPA (or as I like to call it "Liquid Gold"). It's in a spray can. Put your bearing on a metal surface or on a shop towel that you don't care gets grubby, and spray away. It'll take the crud right out from between the rollers.
Once that's done shake it out, blast it with the air compressor, let it dry, and it's ready to repack.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-16-2003, 04:17 PM   #3
sam's 72
cobalt is right, don't use gas! You can also get some varisole, hell I guess that is how you spell it. It works good too!
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 05-16-2003, 04:20 PM   #4
bpmcgee
bpmcgee's Avatar
Working on farm tractors as a kid, I used to clean out tractor bearings with diesel fuel. It's a pretty good solvent -- about like kerosene.
Brian
bpmcgee is offline   Reply With Quote
Old 05-16-2003, 04:37 PM   #5
COBALT
COBALT's Avatar
yeah that's ok. Diesel and Kerosene are oily and have a pretty high flash point (temperature point in which exposed to heat or ignition will actually combust). Gasoline is pretty low (it doesn't take much). The only thing about diesel and kerosene is they sometimes can leave a residue. Brake cleaner leaves nothing. It evaporates pretty quick too.
Seattle, WA.
Old 05-16-2003, 05:32 PM   #6
Linus0014
Guest
Posts: n/a
I thought you are not supposed to use compressed air or similiar on bearings? It doesnt have to be a compressor but next to near. You should let it air dry. I may be wrong!
Old 05-16-2003, 05:40 PM   #7
Mixup
You are not suppose to spin them with air.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 05-16-2003, 05:45 PM   #8
Linus0014
Guest
Posts: n/a
Thank-you for the confirmation. I didnt want to 2nd guess someone who's probably been working on these trucks longer then I've been alive which is 24 years.
