04-26-2010, 02:16 PM | #1 |
"Hooked on Quack"
2 quick questions regarding my 72
1. Pulled the water pump off to replace it and for the life of me I can't figure out how to get the spacer and pulley off to put on the new pump?????
2. I was doing some disassembly this weekend and behind the battery tray mounted to the fender is a black canister with a hose on it that is disconnect what is this, is it important, where do I connect it. Thanks for the help.
Semper Fi, Kevin USMC |
04-26-2010, 02:22 PM | #2 | |
Shake and Bake!
Re: 2 quick questions regarding my 72
Hope this helps. Not sure on the canister, it could be a charcoal canister for evap or ?? Someone will chime in I am sure.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
04-26-2010, 02:28 PM | #3 | |
"Hooked on Quack"
04-26-2010, 02:38 PM | #4 |
Shake and Bake!
Ah, got cha. I would just give it some persuasion, or if there is room where you won't hit the fan bump it with a rubber mallet.
04-26-2010, 02:42 PM | #5 |
Shake and Bake!
Oh and Thank You for your service to this Great Country Kevin!
04-26-2010, 02:53 PM | #6 |
Be careful, the pulley can be easily bent. It's likely rusted onto the snout of the water pump shaft and needs a soaking with WD-40 or your favorite penetrant. Give it a day or two and then try to wiggle it off or gently tap it off. Do not put the pulley in a vice, you will bend/warp the pulley. Ask me how I know. Feel free to put the water pump in a vice if need be.
04-26-2010, 06:54 PM | #7 |
"Hooked on Quack"
thanks guys, I will put the pump in the vice at work tomorrow and soak it for a day or two and then pull it (or tap) it off.
Any clue on the black metal canister? It does have 2 lines that are not used and then on line on it.
