Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-27-2010, 04:04 PM   #1
Ont67shortbox
rear shock help
I am in the process of installing a 9 inch in my 67 shortbox.I went with the Jeep Wrangler springs for an approx 4 inch drop.I have the adjustable panhard bar for centering.What I would like is a single adjustable shock for drag racing to help with the launch.I have looked at several but not sure what part number or length i need.I had 6 inch drop springs and nitro drop shocks( 18 inches extended) but it wasn't working all that well.My 60 foots were around 1.72-1.78.I think I need a stiffer shock . Anyone run them and can give me a bit of help, Thanks Brian
Ont67shortbox is offline   Reply With Quote
Old 04-27-2010, 08:42 PM   #2
djracer
djracer's Avatar
Re: rear shock help
Several guy run Rancho shoks. I they run the Rs 9000's. Super73 might be more help than me.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-29-2010, 10:58 AM   #3
Ont67shortbox
Re: rear shock help
Thanks DJ, anyone else ?
Old 04-29-2010, 02:06 PM   #4
Terry'sToy
Re: rear shock help
QA1 stocker star 1661 might work. 12 way adjustable aluminum shock.
I'm looking for answers too. I see you used jeep coils in the rear. Are they pigtailed at both ends? Do you know the spring rate?
69 GMC 1/2 ton lwb, LS1, headers X-pipe 4L60E Yank 3500 stall 3.73 w/eaton brute force. moroso trick front springs,jeep rear springs, QA1's
Terry'sToy is offline   Reply With Quote
Old 04-29-2010, 02:53 PM   #5
Ont67shortbox
Re: rear shock help
Yes the Wrangler springs are pig tailed,and use a thinner wire than stock Chev spring.Should provide about a 4 inch drop.I had 6 inch drop springs before,but they were short and very stiff.Not sure on the rates. Brian
Old 04-29-2010, 03:18 PM   #6
Terry'sToy
Re: rear shock help
right on, thanks. What year(s) am I looking for?
Terry
Old 04-29-2010, 03:26 PM   #7
Ont67shortbox
Re: rear shock help
mine were from a 90,the owner was raising his and I got them for $30.Try any off road shop that does lifts, you may get them for free
Old 04-29-2010, 03:36 PM   #8
Terry'sToy
Re: rear shock help
good advice, thanks a million. heading to one on the way to my buddies shop right now.
Did you figure out a rear shock yet?
