Old 04-28-2010, 11:59 AM   #376
qu1cks1lver56
qu1cks1lver56's Avatar
Re: my 80 build
my bezels are the same too lol. I thought about painting them body color, but just painted them silver instead.
qu1cks1lver56 is offline   Reply With Quote
Old 04-29-2010, 12:40 AM   #377
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
new wheel
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-29-2010, 01:23 AM   #378
qu1cks1lver56
Re: my 80 build
nice
Old 04-29-2010, 07:45 AM   #379
menace121978
menace121978's Avatar
Re: my 80 build
Looking good Aaron!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-29-2010, 08:28 AM   #380
flamingbig10
6.0 powered square
Re: my 80 build
Originally Posted by qu1cks1lver56 View Post
nice, thanks.
no problem
Originally Posted by bikes&bowties View Post
I just noticed you and I have the same grill/bezels (except my bezels are black to go with mine) and it looks tight on both of our trucks. Your porject came out real nice!
as soon as I got them from classic parts of American, they were a vendor at good guys, I said what ever color my truck is thats what there going to be
nice
thanks
Originally Posted by menace121978 View Post
Looking good Aaron!
Thanks Dennis
Aaron
Old 04-29-2010, 11:20 AM   #381
JohnC
JohnC's Avatar
Re: my 80 build
That looks good man!
JohnC is offline   Reply With Quote
Old 04-30-2010, 08:17 AM   #382
flamingbig10
6.0 powered square
Re: my 80 build
thanks John
Aaron
Old 05-09-2010, 11:43 AM   #383
flamingbig10
6.0 powered square
Re: my 80 build
few parts I 'll be ordering shortly
http://www.classicparts.com/1987-Gas...ctinfo/23-953/
http://www.classicparts.com/1987-91-...ctinfo/23-555/
and I maybe getting a 6.0
Aaron
Old 05-09-2010, 03:37 PM   #384
JohnC
JohnC's Avatar
Re: my 80 build
You may check the shipping on those. I got my tank and unit from O'Reilly, and wasn't much more than that. Just something to check out.
Old 05-09-2010, 10:57 PM   #385
flamingbig10
6.0 powered square
Re: my 80 build
thanks john Oriellys will be a little cheaper but the sender is a lot more though
Aaron
Old 05-10-2010, 09:39 AM   #386
JohnC
JohnC's Avatar
Re: my 80 build
I have noticed the parts places are like that sometimes. When I was looking for the Edelbrock fuel line piece on the carb. Summit has it for like $18, and O'Reilly was $39. Then on something else O'Reilly was half the price of Summit. Never hurts to check around on stuff.
Old 05-30-2010, 04:59 PM   #387
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 80 build
awesome build
Originally Posted by flamingbig10 View Post
i would recomend the mt et street radials
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 06-08-2010, 11:03 PM   #388
flamingbig10
6.0 powered square
Re: my 80 build
Originally Posted by jgh64pkup View Post
awesome build
I give them a look,
the rear end in my tuck starting go so a total rebuild is in order all new bearings and seals, with a 3.73 ring and pinion, with posi track, also maybe rear disc and a deeper diff pan
Aaron
Old 06-10-2010, 09:36 PM   #389
flamingbig10
6.0 powered square
Re: my 80 build
today I went to go some lunch trough the drive through and something caught my eye and I scrapped the curb got back to work and noticed a little scrape so when I got home jacked the truck up and looked at the tank it was fine then I noticed my frame where it was welded where it became a short bed it looks to be cracked so I plan on adding more welds and a gusset
Aaron
Old 06-11-2010, 02:15 AM   #390
qu1cks1lver56
Re: my 80 build
Your truck was a longbed?
Old 06-12-2010, 11:44 PM   #391
flamingbig10
6.0 powered square
Re: my 80 build
yes it was a long bed way before I got, I looked at the welds again and didn't notice any cracks but I still beef the area up though
Aaron
Old 06-13-2010, 12:45 AM   #392
qu1cks1lver56
Re: my 80 build
i wanna turn mine into a shortbed.
Old 06-23-2010, 01:27 AM   #393
flamingbig10
6.0 powered square
Re: my 80 build
the sway bar rivets were getting loose so I drilled out the rivets and installed new grade 8 bolts and new bushings
Aaron
Old 06-23-2010, 11:44 PM   #394
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 06-24-2010, 12:14 AM   #395
flamingbig10
6.0 powered square
Re: my 80 build
summer06
summer 07
summer 08
summer 09
summer 10
Aaron
Old 07-10-2010, 03:05 PM   #396
flamingbig10
6.0 powered square
Re: my 80 build
made my truck a little better driver friendly. At times it would be real hard to start in the mooring or not even start at all so I added new rotor in the distributor and now it fires right up every time, and wile the truck was running you could wiggle the coil cap and the truck would die, so I took it off and noticed were the ground wire goes the plastic was all burnt so added new one and no more problems. While driving my truck 2 years slammed I was tired of it bottom out ever where in the front so added some stubie bump stops I found at pet boys and what a difference ride much better no more banging noise. the my throttle was real had to push down you would have to punch to go, so added a new throttle bracket what difference and looks 100% better, also some led tail lights from lmc there much brighter, there were fairley easy to install
Aaron
Old 07-10-2010, 04:33 PM   #397
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 80 build
awesome
any pics?
Gage
Old 07-10-2010, 07:55 PM   #398
rome704
rome704's Avatar
Re: my 80 build
*didnt look bad into the thread*
How the rig going ive missed out on alot here
Roman "LCPL" Planter
The Few The Proud The Marines
rome704 is offline   Reply With Quote
Old 07-11-2010, 11:28 PM   #399
flamingbig10
6.0 powered square
Re: my 80 build
and rome the rigs going good it get driven every day to work
Aaron
Old 07-12-2010, 12:50 AM   #400
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: my 80 build
awesome
Gage
