Old 04-28-2010, 03:38 PM   #1
rahatawa
rahatawa's Avatar
New Guy Question
I may be posting this in the wrong section but i will give it a go. I have started working on a 64 fleetside and my welding instructor/ friend/ guru has decided he wants a "ton truck." I am taking this to mean a duel rear wheel truck. he is wanting a late 70's or 80's ton. This seems simple enough. The question is this...
Is it possible to put older bodies on these newer vintage trucks? what is involved? any easy swaps? examples of some? links and or pictures. just at the planning stages but any inspiration, ideas or wisdom from you guys would be greatly appreciated.
I got two links to similar but much more modern swaps.
Here is a link to a early Burb being put on Envoy running gear;
http://67-72chevytrucks.com/vboard/s...d.php?t=348244
And a early truck being put on Dodge running gear;
http://67-72chevytrucks.com/vboard/s...d.php?t=393750
I would think that it would require much less work with say moving a 62 cab onto 82 running gear and frame... am i way off base here?
all of the modern trucks and those examples are waaaay more involved than i was thinking. (read involved to mean modern) I was thinking more like the 62 onto the 82 dually. Add a flat bed and ta daaaa...
anybody? just trying to figure it out and get an idea.
and happy hump day
rahatawa is offline   Reply With Quote
Old 04-28-2010, 05:25 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: New Guy Question
rahatawa your links are no good. By "ton truck" he must mean 1-ton. 1-tons had a taller frame channel than the 1/2 and 3/4 ton. Thus a frame swap would be required. Read Scoti's "Project Recycle." He converted a 67-72 frame for use with a 60-66 (not sure exact years). That would be the way I would go. 71-72 1-ton roller (for disc brakes) with 60-66 body. 73-87 would make a decent donor too.
Frizzle Fry is offline   Reply With Quote
Old 04-28-2010, 06:14 PM   #3
rahatawa
rahatawa's Avatar
sorry about the links i will try again
yeah my thoughts were a 73-87 donor for the frame, brakes, driveline etc with a 60-66 body.
so a 73-87 single cab c30 frame and bits with a 60-66ish front sheet metal and cab. i would think the 60's version of a c30 would be a close fit? i may be way off here. no lowering, no notches, no bed. that has to make it easier. i mean at least he isn't asking for it to lay frame and keep the duel wheels inside a fleetside bed.. ha!
Old 04-28-2010, 08:06 PM   #4
62gmc910
62gmc910's Avatar
The 73-80 frame is quite a bit higher at the rear cab mount than the 60-72 profile,
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 04-29-2010, 01:10 AM   #5
Captainfab
60-66 Nut
The '73-'87 frame swap has been mentioned many times......I advise against it unless it is a 4x4. In order to mount a '60-'72 body onto a '73-'87 frame you will end up with about a 3" body lift (BTDT) unless you do some channeling of the body over the frame. As Frizzle Fry mentioned, the '67-'72 frames are a much closer match if a frame is needed. All of the suspension from a C30 thru '87, and CC's thru '91 will work. Although as already mentioned, the C30 frames are a bit beefier than the C10's and C20's
