Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-29-2010, 08:02 PM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
how much HP with a 2 pc DS
ok I think I found a short shart trans for my caddy swap which will allow me to keep the stock 2 piece DS..I'm worried about it holding up with the caddy, pro streets and if I hit it with NOS and the 308 gears there is going to be a ton of strain on it??? I'm thinking around 400 to 500 hp and 400lbs of torque
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-29-2010, 10:39 PM   #2
Captainfab
60-66 Nut
Re: how much HP with a 2 pc DS
IMO as long as you are using the larger driveshafts with the HD carrier bearing you shouldn't have any trouble supporting that much power and even more.
Old 04-29-2010, 11:49 PM   #3
Slofarmtruck
Remember the caddy motors if you are going to run a 472 or 500 make more torque than horsepower. I had a 500 caddy on spray with a TH400 short tail in my 84 Long bed with a custom 1 peice driveshaft with zero issues until I started to try and lower my 60 ft time. Than the U-joints became the week point. That was with a 300 shot of spray though and still walking it out of the hole with drag radials. That motor/trans on a 150 shot lasted forever though. I went through many many bottles of nitrous with zero regard to the drivetrain. Good luck on your build and I guess my advice is to go with a 1 peice shaft as its less parts to break.
Slofarmtruck is offline   Reply With Quote
Old 04-30-2010, 06:02 AM   #4
Hottrucks
Hottrucks's Avatar
thanx Guys
the problem is I don't think the DS is very large ..maybe 2 1/4" or so...
it not tat I dont want a 1 piece but I'm on a budget..maybe I will just behaive until I can ching up ....LMAO..
