05-17-2003, 05:41 PM | #1 |
What is this?
I've been hunting down wiring problems and have found this little gem. I've switched over to an externally regulated alt. When you do that conversion, you connect the white wire to brown wire. I ran the white wire to my alternator. This thing is on the brown wire, half way between the firewall connector and where it clipped into the external regulator. I am unable to get current to flow through it. Does it need to be here? Is this causing my headlight problems? Inside the cab, this wire goes in two directions: 1) to the ignition 2) to the gauge cluster connector. Can I remove this? Anyone?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-17-2003, 09:37 PM | #2 |
huh?
Good question, too bad I don't have the answer.....I'm sure someone does though.
TTT
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
05-30-2003, 05:34 PM | #3 |
Registered Abuser
ttt
05-30-2003, 05:37 PM | #4 |
Registered truck nut
Is that a fuse holder. If so, I'm thinking, it's for the voltage meter in the dash. There should be one just like it running along the other fender to. I'm taking a wild stab here, so....
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
05-30-2003, 05:38 PM | #5 |
SKINNY TIRES RULE!
Is it a fuseable link or a noise suppressor?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
05-30-2003, 05:38 PM | #6 |
Take it out and see if you're getting juice thru it, Maybe it's just a fuse. Try and see. If not you can just put it back in right?
Brandon |
05-30-2003, 06:24 PM | #7 |
It doesn't look like the original fuse holder, but by your description, it's in the correct wire, and location to be the inline fuse for the ammeter. It "should" pull apart to replace the fuse, otherwise, bypass it to see if your electrical problems improve.
69 GMC K10 ..some restoration required....still.. |
