Old 05-01-2010, 11:42 AM   #1
nikwho
nikwho's Avatar
'83- cant switch fuel tanks
I cant switch from the left tank to he right tank in my 83. What is the typical fix needed? I didn't want to just go buy the switch if the problem was with something else. Thanks, Nik
nikwho is offline   Reply With Quote
Old 05-01-2010, 05:54 PM   #2
ppbr2001
ppbr2001's Avatar
Re: '83- cant switch fuel tanks
Try rapping on the switch solenoid. Should be on the passenger side with fuel lines attached.
ppbr2001 is offline   Reply With Quote
Old 05-01-2010, 06:47 PM   #3
nikwho
nikwho's Avatar
well, i tried rapping on the solenoid with no luck. hit it with the handle of a pretty heavy screwdriver. Maybe it'll take a little more of a blow. Maybe a new solenoid?
Old 05-01-2010, 08:30 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Test for power first at the switch valve. Try switching while someone listens to the valve. Sometimes they do get stuck. I had to replace mine.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-02-2010, 01:11 PM   #5
nikwho
nikwho's Avatar
Well, I'll have to check for power and see if I can hear it working tomorrow when i'll have someone to help me. Too bad you can't switch out to a manual valve!
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
Old 05-02-2010, 04:26 PM   #6
ppbr2001
ppbr2001's Avatar
I've always wondered about a braided crossover line.
Old 05-26-2010, 12:41 AM   #7
Jons85
Jons85's Avatar
Did you ever figure out what the problem was? I have an '85 that won't switch tanks either, have only owned it a few weeks now and have just been using the left side but it would be nice to be able to switch and use both tanks since there are both there. The guy I bought it from thought it was the switch which would be an easy fix and cheaper than a new valve solenoid.
1985 C10 "Bagged and shaved"
1986 C10 "4" 6" drop"
2002 F150 Harley Davidson "supercharged" I know it's a ford but the supercharger is fun!
Jons85 is offline   Reply With Quote
Old 05-26-2010, 01:09 AM   #8
wheels67
wheels67's Avatar
Mine stopped working on one side also. It turned out the rubber fuel line had some hairline cracks in it back where it bends aroung the the tank. Put new line in and all was well.
wheels67 is offline   Reply With Quote
Old 05-26-2010, 02:49 PM   #9
Malo83
Cruzzzn' Vet
Malo83's Avatar
Mine quit on me a while back and I replaced the rocker switch in the cab and now she works like new again.
Malo83 is offline   Reply With Quote
