Old 05-01-2010, 05:01 PM   #1
blazntn
Drilling Rotors?
What is involved? I am planning on trading for a set of 5x5 rotors and spindles. But, I am wanting to change it to 5x4.75 to match my vette rearend.
blazntn is offline   Reply With Quote
Old 05-01-2010, 06:17 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drilling Rotors?
www.PerformanceOnLine.com sells a truck rotor that has the 5x4.75 pattern already.
These will work as long as your spindles will work with a 1.25" wide rotors.
(not the 1" wide rotors).
Keith
Convert to disc brakes.
Old 05-01-2010, 07:51 PM   #3
blazntn
ya but cant I just have the rotors I have drilled out to that pattern?
Old 05-01-2010, 08:07 PM   #4
lolife99
lolife99's Avatar
sure.
Keith
Old 05-01-2010, 08:12 PM   #5
blazntn
Do you just lay out the pattern and drill it? How do you put the studs in?
Sorry I have never fooled with the brakes much!!!
I plan on having a friend of my dad's do it for me. He works in a CAT machine shop.
Old 05-01-2010, 11:59 PM   #6
project67-stepside
project67-stepside's Avatar
drilled mine its easy works great< 1/4 holes and countersink bot for bevel>>>
project67-stepside is offline   Reply With Quote
Old 05-02-2010, 06:06 AM   #7
mclairmo
Those holes promote cracks as does a chamfer. It's best to radius the holes to eliminate sharp edges, as opposed to a chamfer. Will also eat pads more quickly.
mclairmo is offline   Reply With Quote
Old 05-02-2010, 07:05 AM   #8
LONGHAIR
He is talking about changing the bolt pattern of the lug studs, not drilling the disc surface.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-02-2010, 08:47 AM   #9
midevil1
ShortBus KingPin
midevil1's Avatar
BB 72 Impala brakes go right on the truck spindles and are 4.75 pattern. Crossdrilling works fine if you dont drill thru the venting..... Never had a pair crack and I have done dozens of sets.
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE)
2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE)
2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE)
midevil1 is offline   Reply With Quote
Old 05-02-2010, 04:33 PM   #10
blazntn
what do those impala brakes run at the local parts store? that might be the best way to go!
Old 05-02-2010, 05:08 PM   #11
midevil1
ShortBus KingPin
midevil1's Avatar
Advanced Auto Parts charged me 100.00 out the door for rotors, calipers, pads, bearings, and dust caps. 72 to 73 will work for sure. Take your wheel bearings down to the parts house and test fit to the races. This is a VERY cheap upgrade for the 67 to 70 trucks and the rotors are 12.25 diameter.
Old 05-03-2010, 09:33 PM   #12
blazntn
Will 1980's models C-10 spindles work on my 69 arms? what do I need to make them work? Might trade my 6 lugs for a guys 5 lug off of an 84!
Old 05-03-2010, 10:59 PM   #13
lolife99
lolife99's Avatar
You will have to change the upper and lower ball joints, and outer tie rod ends.
Keith
Old 05-03-2010, 11:01 PM   #14
Captainfab
60-66 Nut
As long as your '69 is a C10, just change the balljoints and everything else will bolt up. Does your '69 already have power steering?
Old 05-04-2010, 02:43 PM   #15
blazntn
It is a c-10. SO I will just need the newer ball joints. I have a dropmember so the tierods wont be an issue.
