![]() Join Date: Dec 2009
Do you need to change plugs when converting to HEI?
I was just curious if you can use the same plugs (part #) in a 250l when converting to HEI or do you need to change them out? What plugs would you recomm if I want to change them out? Thanks Brandon
What?
Re: Do you need to change plugs when converting to HEI?
I'd just re gap them, since the electronic ignitions require a bigger gap most of the time.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Moderator
![]() Join Date: May 2007
IIRC, it is .050
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Jan 2007
.045 plug gap for HEI is recommended.
so just regap old plugs to .045?
Shake and Bake!
![]() Join Date: Feb 2010
Yep, but there is never a bad time for new plugs
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
20' Daredevil (Ret)
![]() Join Date: May 2003
Yup, same plugs, .035 with points, .045 with HEI.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
I concur. I just changed mine over to HEI. I could have used my old plugs, but used the opportunity to put new ones in (along with new plug wires). I just made sure I adjusted the gaps.
1972 Chevy C10 |
Thank you fellows!
I agree. .050 gap.
Cleaned up my HEI. Confirmed 12v power source. Cleaned up contacts. New cover. Tried to clean/gap plugs till one broke in half.!@#$%^ What was I thinking? NEW PLUGS man. Runs sweet. (here wife...take it for a test drive..she made it back). Darn...juskiddn
"Do not follow where the path may lead. Go instead where there is no path and leave a trail." ![]() Never retired-Always a Marine '72 C10 Longhorn-very daily '86 C10 Van (mothballed) previous; '65 C10 shorty & bunches of M/C's |
