Old 05-02-2010, 12:07 AM   #1
project67-stepside
project67-stepside's Avatar
smc valves wtf!!!!!!
just got the front bags in and decided to check the valves, hooked an air hose up to them and they bleed back through the valves, there hooked up right, valves are new, wtf... i cant proceed on the valves, tanks and the pumps i dont get it hellllllllllllllllllllllllllllllppppppppppppppppppp.....
project67-stepside is offline   Reply With Quote
Old 05-02-2010, 12:57 AM   #2
Thorbecke Bros.
Re: smc valves wtf!!!!!!
Sounds like you were forcing air through the valve backwards which it will bleed through.
Thorbecke Bros. is offline   Reply With Quote
Old 05-02-2010, 01:00 AM   #3
Thorbecke Bros.
Also, if you dont have check valves and you have low or no tank pressure the bag pressure will bleed back into the tank until it equalizes.
Old 05-02-2010, 11:17 AM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
^^right on
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-11-2010, 02:37 PM   #5
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Exactly. Most valves require a minimum pressure on the back side to keep the valve closed.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-11-2010, 05:17 PM   #6
michael bustamante
michael bustamante's Avatar
where do you install the check valves then? just before the the fill valve?
1967custom
michael bustamante is offline   Reply With Quote
Old 05-11-2010, 05:44 PM   #7
BACKYARD88
BACKYARD88's Avatar
I only used check valves when I ran Nitrogen(so I didn't have to lay the truck out to change the bottle). But yes, they would need to be before the fill valve. Once you get the tank and pumps installed they should be fine without check valves. I think the minimum PSI is only around 3-5 to hold the valves closed so as long as you keep that much in the tank they're fine. If you have Viair pumps they have a check valve built in to the leader.
-Mike Owen-
Old 05-11-2010, 05:59 PM   #8
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
""If you have Viair pumps they have a check valve built in to the leader.""
I was just going to say the same thing..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 05-11-2010, 06:11 PM   #9
michael bustamante
nope, running a thomas (thompson?) pump no check valve but Im still building the system, so there shouldnt be any pressure backfeeding thru the valves if I have them plumbed right then correct?
1967custom
Old 05-11-2010, 06:16 PM   #10
kev2809
low n' slo
kev2809's Avatar
a new leader hose from suicidedoors comes with a built in check valve. thats what i bought..
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-11-2010, 06:18 PM   #11
BACKYARD88
BACKYARD88's Avatar
Correct. Just put a check valve between the pump and tank and you should be good to go.
-Mike Owen-
Old 05-11-2010, 06:32 PM   #12
michael bustamante
good deal, thanks, I didnt mean to steal the thread!!!!
1967custom
Old 05-11-2010, 09:23 PM   #13
project67-stepside
Thanks guys i appreciate all the info>>>>>>>
