Old 05-02-2010, 08:17 PM   #1
rhodog77
rhodog77's Avatar
s10 swappers.....shifting linkage
hey guys,
is anyone using the stock s10 automatic shifting linkage or is everyone going with a floor mounting style shifter. any pix or advice would be awesome.
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 05-02-2010, 11:35 PM   #2
Thadious
Re: s10 swappers.....shifting linkage
Personally, I swapped the S10 column for a tilt one from a 73 van and put the ignition back on the dash, but as for shift linkage I went with the Lokar ACA-1800. For all the headaches of trying to use the stock setup, this was dirt easy and clean. 60 bux here in Canada, so wasn't even worth the effort.
Cheers,
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 05-03-2010, 11:18 AM   #3
1952ssr
1952ssr's Avatar
I had every intention on using the original '52 column, but to save money and arrivation I have decided to use the donor S10's. If I could find a swap like Thadious did I would go that route. I think I am gonna try using the stock setup, mine had a 700r4 and I'm going to a 4L60. I think I can swap the gear selector piece on the tranny's and it work.
1952ssr is offline   Reply With Quote
Old 05-05-2010, 01:01 AM   #4
Lrall
Lrall's Avatar
Lokar floor shifter here
Lrall is offline   Reply With Quote
Old 05-06-2010, 10:17 AM   #5
Dan Bowles
AD Addict
5 speed here! Works great. Made a bracket for the slave cylinder.
Dan Bowles is offline   Reply With Quote
Old 05-07-2010, 06:33 PM   #6
rhodog77
rhodog77's Avatar
hey guys, reading on another thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=400144
I looked at my tranny/column setup last night. I think that Im going to keep my column shifter and go with the lokar linkage for my 700R4
http://lokar.com/product-description...lshiftlink.htm
Looks pretty slick and and easy install.....or so I hope!!
1970 P10 Stepvan
