Old 05-03-2010, 03:31 PM   #1
Mrrilla
Mrrilla's Avatar
Neutral/Park Switch signal to ECM
I swappped TPI motor into my truck and everything runs good except I didn't hookup the orange/black (B10) wire that tells the ECM that the truck is esseciatley in drive. The idle RPM could be a little higher when in gear.
I believe the ECM can get this "ground" signal from the Neutral Safety switch except the unit that is in my truck is 4 prong (2 ignition, 2reverse).
I was thinking that maybe I could install a later model truck TBI NSS or something like that. So to everyone that swapped in an EFI motor, how did you send this signal to the ECM?
Attached is a picture of my current NSS
1970 C10 SWB, 67 front clip, 3/5 drop, 350 TPI/700R4, Fiberglass tonneau cover, lots of body mods and.....a ford seat
Mrrilla is offline   Reply With Quote
Old 05-04-2010, 09:45 AM   #2
Mrrilla
Mrrilla's Avatar
Re: Neutral/Park Switch signal to ECM
I found a solution and I thought I'd post my findings for anyone else.
Painless 60122 park/neutral relay kit solves this problem but its about $67. You can also make your own which is what I did. All the parts are available at radio shack and it cost me about $12. Now when going into drive the RPM jumps 75 RPM just like I had planned.
I looked at installing a Neutral safety switch from a 1990 chevy 1500 TBI which also would have worked but the mounted scheme was a bit different.
In my opinion hooking this B10 signal up is important. I know some guys just ground it all the time which is fine but your idle jumps a bit more when in Park or Neutral.
Old 10-15-2011, 09:36 PM   #3
rchavez101
rchavez101's Avatar
I know this is an old post but would this only apply if you have an electronic transmission in your truck? I recently coverted my 94 chevy truck from manual to a Turbo400. When the truck is in gear and you are holding the brake there is a vibration to the truck. If I hold the brake while in gear and give it a little bit of throttle the vibration seems to go away. I contacted a company that programs the chips and he said he could program the chip so that the truck knows it has a auto instead of an automatic. I did tell him it was a turbo 400 so he said I would need to wire in a neutral/park safety switch so the ECM knows that the truck is in gear other then park and neutral. Any thoughts from anyone on this issue?
94 Chevy SWB in progress.
http://67-72chevytrucks.com/vboard/s...d.php?t=477390
rchavez101 is offline   Reply With Quote
Old 10-15-2011, 09:38 PM   #4
rchavez101
rchavez101's Avatar
This is the kit needed to do the wiring or you can do what Mrrilla said above with parts from Radio Shack.
http://www.painlesswiring.com/webcat...rchField=60122
