Old 05-04-2010, 09:22 AM   #1
JimmyFloyd
How do I remove this?
Ok, how do I get this pieces off. It's the u shaped piece that the steering box connects to on the axle in the upper right of the picture. There are 3 bolts holding it on. I have removed them, but it still won't come off. Is there a trick to it, or does it just not come off?
Here is a picture:
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 05-04-2010, 09:40 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: How do I remove this?
You may wanna start by getting some good penetrating oil on there then remove the 3 bolts on top. Iirc the washers are tapered and it makes the whole deal a pita..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-04-2010, 09:41 AM   #3
john8746
john8746's Avatar
Clean it off soak it with blaster Big *@#$%# hammer lots of heat and just beat on it till it brakes loose. It's not easy you will use lots of bad Word before it's off
Good luck
C/10 John N.J.
john8746 is offline   Reply With Quote
Old 05-04-2010, 09:45 AM   #4
JimmyFloyd
Ok, I have the nuts off already, and the steering box, is removed since the picture was taken, just couldn't get it off. I tries a small hammer, but sounds like I need to get the BFH out and give it a whack.
Next question, is it worth keeping if I am not keeping the axle itself? Or am I making more work?
And lastly, how to I remove the Center Link that goes horizontally across that picture? Do I need any special tools?
Old 05-04-2010, 09:51 AM   #5
john8746
john8746's Avatar
You'll need a fork thats made just for the joint it just slides between the two parts one god hit it should pop off ass for the c link keep hitting with a bigger hammer it will come off
C/10 John N.J.
Old 05-04-2010, 09:52 AM   #6
JimmyFloyd
ok, I have the fork I used to remove the steering box still, so that should work for the ends of the Center Link, correct?
Old 05-04-2010, 09:55 AM   #7
john8746
john8746's Avatar
if you don't need the axle let stay right where it is
C/10 John N.J.
Old 05-04-2010, 09:55 AM   #8
john8746
john8746's Avatar
Yes
C/10 John N.J.
Old 05-04-2010, 09:57 AM   #9
JimmyFloyd
ok, That makes things easier. i just need the Center Link cause there is a local guy who wants it, but the rest I can live without. Was just going to remove it so I could sell it, but if it is too much trouble, then I am not going to bother.
Old 05-04-2010, 09:59 AM   #10
JimmyFloyd
Is there anything else there that I should keep?
