04-26-2010, 10:07 PM | #351 |
One day...
Re: Project: Bad Bagged '68.5
Yeah, i like the Auto Meter Ultra lights but havent seen them to match them
05-04-2010, 10:20 PM | #352 |
Well I haven't updated this thread with my dropmember purchase, so here goes. Back in December I got the bright idea to sell my sectioned crossmember and get a dropmember. So I had to pull the engine and trans to do so. While the trans was out, I sold that too! The money is going towards a Tremec TKO 600. I said to myself I'm building a hot rod, so why the hell do I have an automatic in here! It all felt like two steps backward, but I think the end result will be well worth it.
I got a flaming river power rack from Summit. All the dropmember pieces except the actual crossmember I powdercoated myself with an Eastwoods gun. That thing is awesome! So much better than dealing with paint that doesn't have he durability. I also went ahead and got a swaybar from Nate. The only thing that sucked about the whole deal was welding in the rack notches in an already powdercoated from. I took pictures of that but can find them. I felt like I was performing surgery! A couple other notes for the record, I had to cut 1.25 inches off the ends of the rack. I also had to mill down one side of the AirRide upper control arms shafts because they were dished for the factory washer spacer thingys. In this picture you can see the notch surgery. Factory 73-87 brake calipers Last edited by jlaird; 05-04-2010 at 10:23 PM. |
05-04-2010, 10:27 PM | #353 |
Here are some pictures of the stainless hard lines for the air and brakes.
And the tools of the trade. Last edited by jlaird; 05-04-2010 at 10:29 PM. |
05-04-2010, 10:32 PM | #354 |
Here a couple pics of the cab repair that I found which I never posted.
05-04-2010, 10:33 PM | #355 |
insane work! I want a swaybar too now!! How was that to install?
05-04-2010, 10:42 PM | #356 |
OK, back to the steering column. I wanted to make a reinforcement panel on the firewall where the column passes through. I gave me an excuse to use my REINFORCED harbor freight bead roller which is now a beast!
Here is the Flaming River Stainless tilt column and the Ididit mount. Upper column mount is also from Flaming River. |
05-04-2010, 10:43 PM | #357 |
VA72C10
Looking really good!
Looking for a 67-72 swb or blazer project in or around VA. |
05-04-2010, 10:43 PM | #358 |
TNT-MOTORSPORTS
Hey Jlaird.....The clamps you are using for your brake lines and air line.....made 4 you brand ???? How rough a time did you have bending up the lines, did you make patterns out of steel before you did the stainless ? Any problems flaring the stainless other than having to have a 37 degree flare tool ? Sorry if you have answered the questions elsewhere. Tryin to decide what to do with mine.....really like the way you have yours layed out, gonna steel some of your Ideas.
05-04-2010, 10:45 PM | #359 |
Here is the bead roller. I still want to add a steering wheel to it.
This is the back where I added the square tubing. |
05-04-2010, 10:49 PM | #360 |
Some more holes filled on the firewall tunnel area.
Here is a pic of some ads I bought off ebay for the garage. |
05-04-2010, 10:52 PM | #361 |
TNT-MOTORSPORTS
One other question, your power brake booster...who's is it, what brand....I really like it too.
05-04-2010, 10:58 PM | #362 |
OK, time to smooth out the dash where the dash pad used to go.
I cut these out of a piece of steel exhaust pipe because they had the same curve as the dash. Tacked in place. Ground smooth. Yes, I'm a Jr. fan. LOL |
05-04-2010, 11:07 PM | #363 | ||
The booster is a 7" diaphram from CPP as is the Master. |
05-05-2010, 12:00 AM | #364 |
Got a part number on those shocks?
05-05-2010, 07:45 AM | #365 |
One day...
Looks good! I like what you did with the dash!
05-05-2010, 09:29 AM | #366 |
67cheby
why dont you build some of those lines and sell them.... i would buy the first set !!
05-06-2010, 08:23 PM | #367 |
05-07-2010, 01:02 AM | #368 |
On the fast track to nowhere..
Looks good! I culled my sectioned crossmember as well along with my Zed frame. Started on the Dropmember tonight!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
05-07-2010, 01:19 PM | #369 |
Junior Member
Damn nice man! Lookin' real good!
Cory |
06-05-2010, 09:25 AM | #370 |
Squarebody guy
06-05-2010, 01:50 PM | #371 |
Damage Inc
looks like a good project
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
06-05-2010, 02:06 PM | #372 |
dazed and confused
looks good!!
members met: redbaron69, billsbowtie,nc67 |
06-05-2010, 02:45 PM | #373 |
Wouldn't all that work to slick out where the column protrudes through the firewall hole appear better w/the nuts on the interior side of the firewall vs. the engine compartment side?
06-05-2010, 02:49 PM | #374 |
67cheby
that is a clean looking setup
06-05-2010, 02:50 PM | #375 |
Very nice job man. Can't wait to see her finished.
Keep it up! |
