Old 05-04-2010, 11:52 PM   #1
BLUE THUNDER
BLUE THUNDER's Avatar
Carb question
I've got a question for you guys. Recently I bought an Edelbrock electric choke carb. It runs great. The problem i'm having is that after I turn the motor off and wait 15min it is really hard to start. I have to step on the accelerator and leave it wide open to start. It runs rough for a couple of minutes and a plume of smelly "gas" smoke comes out of the pipes. What can I do to fix it?
BLUE THUNDER is offline   Reply With Quote
Old 05-04-2010, 11:56 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: Carb question
Sounds like it is staying choked even after it warms up. They are adjustable if I remember correctly. Going off memory you need to loosen the choke housing and turn it counterclockwise a little.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-05-2010, 01:16 AM   #3
old man jimmy
Re: Carb question
could be the floats set too high. Letting it flood the intake with gas after you shut it down. Pull your breather and watch the top of your carb when you turn it off. If you see a bunch of fumes coming up, it's probably flooding itself.
old man jimmy is offline   Reply With Quote
Old 05-05-2010, 02:02 AM   #4
Blizz
Blizz's Avatar
Re: Carb question
it sounds like you have to adjust the flux capacitor about 8degrees and make sure the battery is giving you 1.21 jigawatts.
'72 K5 CST Blazer 4x4 in perpetual progress
'96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon
Blizz is offline   Reply With Quote
Old 05-05-2010, 07:46 AM   #5
pound41
Re: Carb question
Sounds like the reason I have a 1406 sitting on a shelf with about 150 miles on it
pound41 is offline   Reply With Quote
Old 05-05-2010, 08:50 AM   #6
Blizz
Blizz's Avatar
Re: Carb question
that settles it...i was thinking of buying a new 1405 or 1406......1405 it is.
Old 05-05-2010, 11:03 AM   #7
Critter
Future TOTM Winner
Critter's Avatar
Re: Carb question
If it's the floats like old man jimmy said you could still have the exact same problem with a 1405. Either way, they are all adjustable (choke and float) and its not uncommon to need tinkering.
Old 05-05-2010, 11:22 AM   #8
hotrodhomi
hotrodhomi's Avatar
Re: Carb question
http://www.edelbrock.com/automotive_...ech_vids.shtml
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 05-05-2010, 09:37 PM   #9
Longblock
Longblock's Avatar
Re: Carb question
Mine did the same thing......just turn it a little at a time..... it fixed mine....
Longblock is offline   Reply With Quote
Old 05-05-2010, 10:05 PM   #10
AlaskaMatt
AlaskaMatt's Avatar
Re: Carb question
EDIT: after re-read you are flooding it. Either with the choke staying on, or you really need to check the floats. Also do you have the right fuel pump? They can only handle something like 5 psi.
Also you can adjust where the electric choke comes in, I turned mine way down. The 1406 can be great, it does require tuning/tweaking to get it just right.
Thanks,
Matt
My Website
AlaskaMatt is offline   Reply With Quote
Old 05-06-2010, 12:25 AM   #11
BLUE THUNDER
Re: Carb question
Thanks guys for the input. I'm gonna adjust the choke a little at a time to see if that fixes the problem. I'll keep you posted.
Old 05-06-2010, 04:41 PM   #12
D-Rat
D-Rat's Avatar
Re: Carb question
do you have a carb spacer, or is it bolted directly to the intake? I had this problem with my new edelbrock because I had no spacer, and the hot intake was boiling the fuel out of the bowl, making it start hard when warm. I added a 1/2" spacer and the problem disappeared.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 05-06-2010, 07:12 PM   #13
BLUE THUNDER
Re: Carb question
What kind of spacer did you get? Where did you pick it up? How many carb gaskets will I need?
Old 05-09-2010, 01:32 AM   #14
AlaskaMatt
AlaskaMatt's Avatar
Re: Carb question
I was going to mention the spacer as well. I found in stock at local parts store. Get the plastic ones as the aluminum ones defeat the purpose by transferring heat up into the carb.
Thanks,
Matt
My Website
Old 05-09-2010, 12:35 PM   #15
Dusty71blazer
Dusty71blazer's Avatar
Re: Carb question
Mine came with a 1407. Other than being wwaaayyy too rich- I have no problems.
I'm planning to downsize to a 1405 for now... hopefully FI in the future.
Dustin
'97 Dodge Ram (daily driver)
'71 Blazer (supposed to be a toy... insists on being a project)
'85 Monte Carlo SS (project)
Dusty71blazer is offline   Reply With Quote
