Closed Thread
Old 05-06-2010, 06:30 PM   #3101
robmrtnbb5
robmrtnbb5's Avatar
Re: How about some pics of 67-72 Trucks
few more shots
bondo bob
http://s424.photobucket.com/albums/p...albumview=grid <<<link to my stuff and project 68 step side build
robmrtnbb5 is offline
Old 05-06-2010, 06:40 PM   #3102
robmrtnbb5
robmrtnbb5's Avatar
Cool Re: How about some pics of 67-72 Trucks
few more
bondo bob
Old 05-06-2010, 07:44 PM   #3103
smbrouss70
smbrouss70's Avatar
That is REALLY NICE!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline
Old 05-06-2010, 10:04 PM   #3104
djracer
djracer's Avatar
Originally Posted by robmrtnbb5 View Post
few more
That is sweet. Is it all show or will it go? You should post pics in the racin section I'm sure the guys there will dig it also.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline
Old 05-06-2010, 11:12 PM   #3105
Longhorn321
Size Matters
Longhorn321's Avatar
few more shots
Are those BMW seats?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline
Old 05-07-2010, 03:41 AM   #3106
robmrtnbb5
robmrtnbb5's Avatar
Yes those are bmw seats you wont blive how i came up with them. they were seting in some one's front yart with a shing free plese take them .BMW said they are about $2500 a pice one lucky day
bondo bob
Old 05-07-2010, 03:44 AM   #3107
robmrtnbb5
robmrtnbb5's Avatar
not all shoW it will goooooo with close to 900 HP
bondo bob
Old 05-07-2010, 03:47 AM   #3108
robmrtnbb5
robmrtnbb5's Avatar
Originally Posted by smbrouss70 View Post
that is really nice!
thanks very much came a long way since last year its under project 68 step side
bondo bob
Old 05-07-2010, 03:48 AM   #3109
robmrtnbb5
robmrtnbb5's Avatar
thanks very much got a lot done in the last year
bondo bob
Old 05-07-2010, 08:50 AM   #3110
bobshotrodblazer
BigBlockBobby
very impressive work . Nice Job!
Bob
bobshotrodblazer is offline
Old 05-07-2010, 08:51 AM   #3111
Longhorn321
Size Matters
Sweet!!
...WOOOO HOOOO!!!!
Old 05-07-2010, 12:10 PM   #3112
69_C10_LS1
My project in progress...
Rick
1969 Chevy C-10 Short Bed Pick Up
Chassis:
• Stock frame with custom engine and transmission mount powder coated gloss black
• Rock Valley stainless steel gas tank with LS1 in tank fuel pump
• Flat Out Engineering front end with Corvette suspension components
• Corvette Rack & Pinion - painted to match exterior body color
• Baer Tracker adjustable tie rod ends
• Baer GT-Plus Front Brake system with 13.5” 2 piece rotors
• Baer GT-Plus Rear Brake system with 13.0” 2 piece rotors
• KYB Coil over shocks with 2” of ride height adjustment - painted to match exterior body
• Early Classic Enterprises Extreme Drop Center Cross Member
• Early Classic Enterprises Super Track Bar Relocating Kit
• Early Classic Enterprises Rear Shock Relocating Kit
• Early Classic Enterprises 6” Drop Springs - painted to match exterior color
• Early Classic Enterprises Heavy Duty trailing arms (boxed steel) - powder coated gloss black
• Stock Rear End - powder coated gloss black
• Brand new 5 lug axles, Strange positraction, 4.11 Motive Gears
• 20” Foose Nitrous II custom polished wheels with 255/40/20 front and 275/45/20 rear tires
Engine/Transmission:
• 2001 Corvette LS1
• 2006 GTO T-56 6 speed
• F.A.S.T. 78mm intake manifold, 36 lb injectors
• Stainless steel 13/4 inch full length headers with 3” exhaust and dual Magna Flow mufflers
• Camaro LS1 serpentine belt drive with alternator and power steering
• Street & Performance motor mounts
69_C10_LS1 is offline
Old 05-07-2010, 12:11 PM   #3113
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Ummmm......we need more pictures and more info..........!!!!!!!!!
ksbrktracer is offline
Old 05-07-2010, 12:23 PM   #3114
69_C10_LS1
Post updated with info
Old 05-07-2010, 12:55 PM   #3115
colin_havens
colin_havens's Avatar
few more
How do you like the intergrated blinkers in the headlights? Can you see them well? And where did you get your billett grill? That is the setup I have wanted to go with for a while, but I cant seem to find the billett grill anywhere that the bottom one is not short for the origional blinkers.
colin_havens is offline
Old 05-07-2010, 12:59 PM   #3116
Longhorn321
Size Matters
Would it be possible to use two top pieces? I realize that would probably double the price but....just a thought.
...WOOOO HOOOO!!!!
Old 05-07-2010, 01:10 PM   #3117
robmrtnbb5
robmrtnbb5's Avatar
Originally Posted by bobshotrodblazer View Post
very impressive work . Nice job!
thanks bob
bondo bob
Old 05-07-2010, 01:12 PM   #3118
robmrtnbb5
robmrtnbb5's Avatar
Originally Posted by longhorn321 View Post
would it be possible to use two top pieces? I realize that would probably double the price but....just a thought.
yes u can use two top pice's
bondo bob
Old 05-07-2010, 01:17 PM   #3119
robmrtnbb5
robmrtnbb5's Avatar
how do you like the intergrated blinkers in the headlights? Can you see them well? And where did you get your billett grill? That is the setup i have wanted to go with for a while, but i cant seem to find the billett grill anywhere that the bottom one is not short for the origional blinkers.
i think you CAN get 70 BILLET grill and cut it apart A FREIND OF MINE OWNS THE CARAGE WORKS THEY MAKE THE BEST GRILLS ON THE MARKET I JUST WENT UP TO HIS PLACE AND GOT TWO TOP'S AS WE USED WORK TOGATHER I SELL A LOT OF HIS GRILLS I WILL CHECK WITH HIM MABY I CAN HELP U OUT
ROB
bondo bob
Old 05-07-2010, 01:47 PM   #3120
ksbrktracer
TNT-MOTORSPORTS
Originally Posted by Stano View Post
I havent posted here in a while been a member for years great site. Here are a few pics of my 67 I built several years ago.
I am curious as to what brand of hood this is ? steel or fiberglass ? Like the looks of the truck too......!!!!
Old 05-07-2010, 01:49 PM   #3121
ksbrktracer
TNT-MOTORSPORTS
Shoot....the picture didnt come thru....Post 8727....Stano.....Cowl hood on black 67
Old 05-07-2010, 02:23 PM   #3122
olebigblue
olebigblue's Avatar
Originally Posted by Burb View Post
Welcome ... can't wait to see the paint.
I second that!
- '71 C10 LWB (Big Blue)
- '03 Honda VTX 1300 Retro
- '09 GMC Acadia (Family Car)
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=395044
olebigblue is offline
Old 05-07-2010, 02:24 PM   #3123
olebigblue
olebigblue's Avatar
Amen!! That thing is bad azz
Build Thread
Old 05-08-2010, 10:27 AM   #3124
70shortfleet
70shortfleet's Avatar
This is my on going project sense 1984 It was finished then I took it apart to clean up the rust that I had covered up. This is a 1970 CST that was sold to a leasing company in Fresno CALF. in 1970. How it got to St. Louis, Mo. I do not know! I sold it to a friend of mine in 1987 and got back in 1989. I took it apart about 5 years ago and this is as far as I've gottin! I'm not the fastest guy in the world. I am new to this site and after seeing all the projects I am getting the bug again.
70shortfleet is offline
Old 05-08-2010, 11:54 AM   #3125
Blitz
Mr. Thread Killer
Gonna be needing more pics!!
Blitz is offline
Closed Thread
