Old 05-07-2010, 01:06 AM   #1
jake wells
i have some tires and rims will they fit my truck
they are wagon wheels off of a 73 chevy. the tire size is 31.10-15 will they fit on my half ton or not?
jake wells is offline   Reply With Quote
Old 05-07-2010, 01:12 AM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: i have some tires and rims will they fit my truck
Need more info. Is your truck a 2x4 or a 4x4? Did the wheels come off a half-ton? Did they come off a 4x4 or 2x4?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 05-07-2010, 01:54 AM   #3
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I'm running 31.10R15's on my 78 with no problem. 2WD half-ton.
78 Big10 454 is offline   Reply With Quote
Old 05-07-2010, 02:48 AM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Ya x2 the tires should fit fine just need to know what rims you got and what kind of truck your putting them on
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-07-2010, 01:06 PM   #5
jake wells
the tires and rims are from a gmc sierra from 73 it was a half ton 5 lug.
mine is a 79 gmc sierra grande half ton with 5 lugs. somebody told me not to use them as they are wider than the stock wheels and would rub in the wheel wells so i need a opinion both trucks are 2wd.
-Jake
Old 05-07-2010, 01:50 PM   #6
nlped
nlped's Avatar
^^^ Yes they will fit as far as bolt pattern. Now as far as if it will rub or not, that depends on the rim width, rim offset and such. My '76 2wd Blazer has 15x8" wheels with 31x10.50r15's on it, but it has been lifted slightly. Simplest way to confirm fitment is to bolt one up on the front and pull forwards and back slightly to get the suspension to settle and then turn lock to lock a few times. If you can't do that, post up the backspacing and width on the wheel. If nothing else, post a pic. A lot can be told from a picture.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
