Old 05-07-2010, 02:51 PM   #1
TurnNBurn
Dash Cluster wire diagram 78 C-10 2wd
Hello I need to find a gauge cluster wire diagram so I can wire in some new gauges. Can anyone help me out
One more question what ohm rating is the fuel sender in my 78??
Thanks all
TurnNBurn is offline   Reply With Quote
Old 05-08-2010, 02:03 AM   #2
73chevyman
73chevyman's Avatar
Re: Dash Cluster wire diagram 78 C-10 2wd
if you still have the green board trace threw that and it will tell you what is doing what... also do a google search and see what you come up with
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 05-08-2010, 09:20 AM   #3
misternash2
i did a gauge swap in my 85 for electronic speedo setup out of a 90 burb. what you need to do is pull your instrument cluster, and you'll see pin numbers on the plug. take your time and write down what pin number you're looking at, then trace where it goes. this will tell you what wire you've got. write down everything you see, i had written down the original plug numbers, what color wire was in them, then traced out where it went on the printed circuit board. you'll have a power, a ground, and a signal wire for each gauge, but you'll notice that one wire goes to more than one gauge. take your time and you'll get it. my advice is not to rush through it if you don't have much wiring experience. it took me about two and a half hours or so to do the gauge swap just because i was writing everything down and taking my time to get it done, but i had two gauge sets to trace out and had to repin my original plug connector.
if you need any more info or help, pm me and i'll do my best to get you rolling again or at least point you to someone who can if i can't.
NASH
misternash2 is offline   Reply With Quote
Old 05-08-2010, 04:48 PM   #4
Prong
The fuel sender ohm range is 0 (empty) -90 (full).
Prong is offline   Reply With Quote
