#1226 |
Redneck Hillbilly
Re: What did you do to your truck today?
#1227 |
![]() Join Date: Sep 2006
I happen to be riding by the Napa store on my way home and remembered to stop and get some plug wires.. yee hawww.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#1228 |
wasted a lot of time thinking about it and looking at stuff on here
#1229 |
It's not "wasted time" if it is what you wanted to do.
Life is short, enjoy the ride! |
#1230 |
Picked up a 1.25 inch front sway bar off a 88 chevy 1 ton to install on my 65 C10 :-)
#1231 |
#1232 |
Member of the longbed union.
I know you all wanna see pics, but I never take them. I did actully work on the truck today though. I started the wish bone 3 link. Still need to build the crossmember for the links, but it's a start.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#1233 |
i finally got back to the burban last couple of days, '62 GMC ona '73 4x4 chassis.
started on layin up the roll cage/chassis structure/body mounting. its mainly gonna be a tow/recovery/camping rig, for the desert truck, and misc adventure running. the cage goes thru the floor to chassis Last edited by Franks Fab Shop; 05-07-2010 at 12:25 AM. |
#1234 |
bump
#1235 |
I replaced the modern rubber ducky with a chrome original style antenna.
#1236 |
fitting my 69 rear end up to my 64, started to mount up the rear mounted gas tank, bought few small parts, nuts bolts, gaskets, etc, bought rear notch, rear drop springs(5 inch) rear drop shocks, started to fab up rear drop blocks ( 3 inch blocks) pulled cover off of rear end and filled her up with some good ol' oil. looked at a new fleetside box all good metal. installed my kick ass gun mounts! HAHA. starting to see the light at the end of the tunnel!
#1237 |
HOW long until spring??
![]() Join Date: Mar 2009
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#1238 |
Senior Enthusiast
Congratulations! Good for you.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#1239 |
Senior Enthusiast
#1240 | |
'66 C20 converted to C10, 454/TH400 '66 C10 saved from crusher ![]() |
#1241 |
I spent yesterday driving from Atlanta GA to Baton Rouge LA to pick up a SWB 4x4 frame from board member 62 short step. Today I picked it up and tomorrow I drive back. Great to meet another board member.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
#1242 |
Redneck Hillbilly
Looked for the vin number tags with no luck. Now after getting out of the shop I found the replies to my thread asking about this issue, so I should be able to find the number later on tonight or tomorrow. I also pulled the front wheels off so I could swap the flat tires out for an old set of rollers I had laying around. Now at least she will roll without firing up the compressor every time. I have to wait until I get the paperwork going before I get too involved in tearing her apart though.
#1243 | |
#1244 |
Redneck Hillbilly
Yeah, that's gonna be my last resort spot. Until reading the answers to my post I had no idea that GM put the vin tags on the upper side of the door jam on the trucks (I've always built cars and was looking in all the car places). I'm gonna go back and check the door jam again, if it is as empty as I think it is then I'll just get it off the frame. Thanks.
#1245 | |
![]() Join Date: May 2009
#1246 |
Redneck Hillbilly
Went out to the shop this morning and found my vin number. After looking at some of the decoders in this site I learned my truck is actually a 1965 C-10.
#1247 |
What i did on the truck today..?
DROVE IT !!! |
#1248 |
i put the rear end up on jackstands and yanked the rear drivers side brake line that sprung a leak, went out to my moms and jacked the line off of a 67-72 half ton pu box trailer i put out there for her to use. getting ready to head back into town and get that brake line put in and try to finish pulling the old u bolts out of the trailing arms, ordering new ones for my 3 inch blocks i welded up this weekend
#1249 |
One day...
Got my mock up engine in the truck, installed some headers laying around so i know how to fab the trans mount to clear the muffler pipe.
#1250 |
Drove my crazy LT1 swap around the block for the first time.
- Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already. 1995 Impala SS - LT1/T56 Combo. This is my 1st priority project. |
