05-10-2010, 01:16 PM | #1 |
air bag help, truck bounces alot
So I have a 67 c10 that im currently working on, here is the set up. Its a scsb 350 and 400 trans, the front set up is 2600 series bags with ebay plates on the control arms and 3" drop spindles. Right now it has no sway bar but when test driving after the bags were put on it would bounce alot when aired out. From what I have read it should bounce hardly anything when aired down. Or do you guys think it could be the shocks that are bottomed out. Well any help would be appreciated, thanks everyone
05-10-2010, 01:27 PM | #2 |
I'm just glad to be here!
Re: air bag help, truck bounces alot
First let me say that I am not a "bag" guy. But, if it is "aired out" wouldn't that mean that it is sitting on the bumpstops or bottomed out? If it is, there is no suspension to soak up any bumps in the road and depending on your tire's sidewall and pressure in the tire, your ride would bounce on any bump you hit...
Am I off base here?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
05-10-2010, 02:05 PM | #3 |
That makes scense, I might Have just read wrong before.... Thanks for the input though
05-10-2010, 02:15 PM | #4 |
did you relocate or use lowered shocks?
1967custom |
05-10-2010, 02:43 PM | #5 |
You shouldnt be driving the truck aired all the way down. The whole trucks weight will be resting on a fully collapsed bag. You basically have no suspension when you do that. It really should only be laid out when you park it. You need to determine a ride height and use it when driving.
05-10-2010, 03:18 PM | #6 |
The shocks are in stock location, and you have a point about driving aired out, thanks for the help guys
05-10-2010, 05:10 PM | #7 |
The lower the air pressure, the less 'spring' rate the suspension will have. There will be a cross-over point where the shocks will be doing more work than merely controlling susension occilation. Once that happens, you'll really start noticing the 'bounce' (same thing if the shocks are weak @ normal ride heights).
05-11-2010, 06:25 AM | #8 |
Yeah no air= no springs it will bounce around if you want it to have a super low ride height you need a dropmember.
