Tie rod adjusting sleeve question
Hope this isn't to dumb of a question, but I'm not a front end expert by any means. I just replaced the tie rods on my 62 1/2 ton, but kept the stock adjusting sleeves (LOOKED FINE) and after adjusting the toe in, tightened up the nuts on the sleeves. The question is, should I still be able to turn the sleeve in or out. I can put my wrench on it, and turn it kind of easily - doesn't seem right, shouldn't the nuts on the sleeve keep it from turn
Re: Tie rod adjusting sleeve question
Yes, they should keep it from turning. i think the torque is around 22 ftlbs on those bolts.
That's what I thought, time to spend more money on new sleeves I guess
I just got some new aluminum sleeves from CCP. Havnt installed them yet but they look like a great product
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
BMW & ASE Master Certified
depends on what your talking about.... is it turning on the threads, or pivoting on the ball joints. If you tighten the jam nut good an tight.. to spec even... you couuld get a pair of channel locks and grab hold of the sleeve and rotate it a bit. It doesnt rotate the sleeve itself, it rotates everything... take a look at that and see if thats whats happening.... more than likely, thats what happening
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
