Old 05-10-2010, 04:12 PM   #1
Bennett68C10
Bennett68C10's Avatar
Need Pics of Hooker Comp SBC Long Tubes
I need pics of how the collector hangs at the bottom. If anybody has pics from the side or underneath that would be great. My truck is going to be lowered so i just want to see how low they hang. Thinking of getting the black painted ones from summit for $196.00 and then having them coated later on when i have more money. I really like the Doug Thorley's but the are a bit pricey and they don't hang to low from the pics i have seen, not like the Hedman longtube pics i have seen. My truck is going to have a 4.5-5" drop in the front with 255/60/15 tires depending on whether i use 2" or 2.5" drop spindles. I really want to run long tubes and not shorties.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-10-2010, 04:40 PM   #2
sleepertruck72
sleepertruck72's Avatar
Re: Need Pics of Hooker Comp SBC Long Tubes
Here are some pics of mine
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 05-10-2010, 06:43 PM   #3
Bennett68C10
Thanks sleepertruck72 they look like they sit about even with the control arms and front crossmember. Did you have any fitment problems? My plans are 15x8 rally's in the front with 255/60/15 tires and 15x12 rally's in the rear with 29x15x15 MT Sportsman S/R. I can thank prostreetc-10 for that lol. After seeing his truck i want a similar setup.
Keith
66 Suburban
IG: bennett68c10
Old 05-10-2010, 07:12 PM   #4
LMN8UR
LMN8UR's Avatar
These are pix as I was taking the tired engine out. The headers don't have much wiggle room between the starter, frame, and clutch linkages.
Tires won't be an issue. But putting these in require following the instructions. I spent more time trying to figure out the short cuts, then I realized the boys at Hooker have been to this rodeo before. (And I was just the clown!)
Name:  Old engine 01.jpg
Name:  Old engine 02.jpg
Good Luck!
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 05-10-2010, 08:09 PM   #5
Bennett68C10
Thanks LMN8UR i only listed the tire sizes so everyone can get an idea on the stance the truck is goin to have. You wouldn't by any chance have any pics of how the collectors hang at the bottom do you.
Keith
66 Suburban
IG: bennett68c10
Old 05-10-2010, 11:30 PM   #6
pmpski_1
pmpski_1's Avatar
If you can swing it, get the ceramic coated ones right off the bat.
1. You don't have to remove them later and wait for them to get coated
2. They get grungy pretty quickly. Unless the price of getting them coated includes stripping them for prep, it will be a real PITA later
3. You won't have to install them again.
I chose the same route as you - get them now, coat them later. I really wish I had gone the coated route first. I've RR'd these more times than I care to admit and while it's not hard, it's just a pain. Just my 2 cents, install them once and forget about it.
pmpski_1 is offline   Reply With Quote
Old 05-11-2010, 08:07 AM   #7
68Stepbed
68Stepbed's Avatar
Amen!
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-11-2010, 08:24 AM   #8
Bennett68C10
I was going to get them uncoated cause i have heard that hookers coating is pretty bad and rusts thru pretty quickly but i did find that i can order the hookers straight from jet hot with their coating on them. Might go that direction.
On a side note my dad has some old cast iron manifolds off his 94 GMC 350 would I be able to use them to break in a cam on my 350. I have a GM 350/250 crate motor i picked up off a buddy for $400.00. This is the other reason i was going to go with uncoated headers cause i can't break a cam in on coated ones.
Keith
66 Suburban
IG: bennett68c10
Old 05-11-2010, 05:07 PM   #9
bigsnookmaster
bigsnookmaster's Avatar
I would get them uncoated, and have them coated. I bought a set of coated Hooker Super Comps from Jeg's and they didn't last very long at all! I took them to a local coater and had them stripped and coated and they have worked very well since then. My .02
bigsnookmaster is offline   Reply With Quote
Old 05-12-2010, 08:02 AM   #10
Bennett68C10
Quote: I would get them uncoated, and have them coated. I bought a set of coated Hooker Super Comps from Jeg's and they didn't last very long at all! I took them to a local coater and had them stripped and coated and they have worked very well since then. My .02
Thanks that is what is was thinking about doing from the beginning, buying the black painted hooker comps breaking my cam in with them and then having them ceramic coated after.
Keith
66 Suburban
IG: bennett68c10
Old 05-12-2010, 01:11 PM   #11
68Stepbed
68Stepbed's Avatar
First, why do you need to break-in the cam? Did you change the stock cam? Second, why can't you use coated headers?
Matt
Old 05-13-2010, 07:29 AM   #12
Bennett68C10
I'm changing the cam to a little beefier cam i like the way your truck sounds with the xe262 might go in that direction. Not going to go to radical yet with the stock heads. I saw that you have a GM Crate which version do you have and did you change your valve springs with the cam or use the stock ones.
Every company i have read whether it be Hooker, Hedman or even Jet-Hot all said that the cam can't be broken in with coated headers. The break in process produces more heat than normal and will ruin the coating. You also lose any warranty you have on the coating. I was just going by what i read.
Keith
66 Suburban
IG: bennett68c10
Old 05-13-2010, 08:30 AM   #13
68Stepbed
68Stepbed's Avatar
OK, Gotcha.
I have the 260hp crate engine. I wanted to go with the XE268 cam but the guys at COMP CAMS said I would defintely have to change valve springs with it. They recommended the XE262 if I was gonna use stock springs and stock converter. They still recommended new valve springs with any cam bigger than stock, but they would be ok with the XE262. I also added COMP Magnum roller tipped rockers, and a double roller timing chain. I need to get some poly-locks for the rockers eventually.
Matt
Old 05-13-2010, 10:37 AM   #14
Bennett68C10
Oh ok thats the same crate motor i have, jegs lists it as 250hp and summit lists it at 260hp lol. I was thinking of going with the comp magnum 270h k-kit with the new springs, retainers and double roller chain. Also plan on running a 2000-2200 rpm stall and a turbo 350. Should make a nice little combo. I already have a Performer RPM manifold and a 600cfm edelbrock. Might upgrade the carb as well to a 650 demon or 670 street avenger.
Keith
66 Suburban
IG: bennett68c10
Old 05-13-2010, 11:57 AM   #15
68Stepbed
68Stepbed's Avatar
Cool deal, man! That should make for a nice combo. I recommend the Holley 570 Street Avenger carb. You still wouldn't need the 670 unless you upgraded the heads.
Matt
Old 05-13-2010, 12:46 PM   #16
Bennett68C10
Yeah i want to down the road after i get the truck built updrade to afr 180cc street heads, but that is way down the road lol. I'll probably stick to the edelbrock 600 until i upgrade heads.
Keith
66 Suburban
IG: bennett68c10
Old 05-13-2010, 05:20 PM   #17
AustinScott
AustinScott's Avatar
I have super comp headers, not sure if that makes any difference.
check out the video, at the start there are a some still shots & video of the headers. I have more pictures if you want them, just let me know
http://67-72chevytrucks.com/vboard/s...d.php?t=397023
Scott
AustinScott is offline   Reply With Quote
Old 05-13-2010, 08:06 PM   #18
xrod
sleepertruck,
What exhaust system are you running with those headers? Is it a bolt on system or are some mods required?
xrod is offline   Reply With Quote
