05-11-2010, 11:53 PM | #1 |
OL BLUU
Engine ideas please....
So I'm looking at putting another engine in the 82' Blazer. Right now it appears it has a mild 305 with bottom end work already done previously. Currently I changed the main bearing and rod bearings and the crank showed signs of some overheating, scaring, etc. I'm still having a knock in the #2 piston so I'm looking at replacing the whole thing.
Here are a few of my question: 1. If I buy a rebuilt long block; will my current Eldenbrok manifold, carb, acc brackets, etc bolt up to a 350 block? 2. Is it a mojor task to install a TBI set up in it? I'm just starting to research this... I'm pretty new to the whole "engine" side of things... my budget is about $1500 with my dad/brothers and I doing the labor part. Also I'm looking for gas mileage... not just torque etc. Any suggestions?! Thanks as always! Anthony
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 05-11-2010 at 11:57 PM. |
05-12-2010, 12:09 AM | #2 |
Re: Engine ideas please....
If you want mpg i would look in a ls and 4l80 you can get one the lq truck engines cheap.
05-12-2010, 01:09 AM | #3 |
Garage wrench
A good option would be a longblock from GM Performance Parts...
http://www.summitracing.com/parts/NAL-12499529/ But, it's over budget. I'd say look into your local parts stores, ie o'reilly's, advance auto parts, etc. and see if they offer a longblock that will drop in. I think if you stick with an 80-85 GM V8 block most everything should transfer over. An LSx engine swap would be very nice for both power and mileage but $1500 is way short of getting it in and running reliable. If it were me on that budget I would look for a running old pos truck for around $500 or so and transfer the engine to your blazer. The ideal situation would be to get something with a warranty for piece of mind.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
05-12-2010, 10:40 AM | #4 | |
Happy to be here
If it were me and I had a 1500.00 budget, I would look at finding a running 88-91 Burb. I have seen them with fairly low mileage for a decent price. Buy the motor or the entire truck and sell of the remains. SBTork- I guess I should have scrolled down the page and read your post before responding...
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 05-12-2010 at 10:41 AM. |
05-12-2010, 10:58 AM | #5 |
Slots go on anything!
I second parting out a 89-91 burb. If you don't already have an overdrive trans, you can get that, too. That, and the FI setup. It might be a lot less hassle to use an aftermarket harness if you are not sure about wiring it up, but it isn't really that bad. The only downdide is pulling two dashes completely apart to get all the wiring you need.
If you do decide to go with a crate engine, everything from your 305 will work just fine. A 350 may actually make your mileage go up (probably not drastically, though) just by having the torque to get it to move. Even injected, I doubt you will see anything over 20, probably more realistically in the 15-18 MPG range.
1974 Jimmy- 5.3/4L80e/NP241 |
05-12-2010, 11:12 PM | #6 |
OL BLUU
Thanks for the input and advise... here's a few options I found today:
1. Reputeably engine shop will sell a 305 long block for $850 O.T.D. and $1050 for a 350 O.T.D... both with 12/12K mile warranty. This same shop will install for an additional $750 and it will increase the warranty to 18mth/18K miles. 2. Called a Pick and pull and they had a 305 complete w/85K miles for $350 O.T.D. or a "freshened up" complete 350 for $750 O.T.D and me doing the labor. These both came with a 90 warranty only. Sooooo any wise input from the people who have been thru this before?!?! I wasn't planning on sticking an engine in it this soon... definitely caught me by surprise. Thanks, Anthony
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 05-12-2010 at 11:12 PM. |
05-12-2010, 11:23 PM | #7 |
Happy to be here
Anthony- The age old saying is their no replacement for displacement. There is nothing "wrong" with a 305, but a 350 is the way to go.
If you have the extra cabbage the deal at the local shop sounds pretty good.
05-13-2010, 01:50 AM | #9 |
Garage wrench
Anthony - If you can do the work, and it seems like you can, go with the 350 for $1050 O.T.D. and install it with your helpers. It's hard or impossible for any company to warranty an engine out any longer than 12/12 because they don't know how you are using it. It seems like a decent deal.
I see you say "reputable" engine shop, do you know of anyone that has had work done by them? Just asking if you have any first hand experience.
05-13-2010, 09:51 AM | #10 | |
I know the pieces fit
05-13-2010, 10:11 AM | #11 |
Keep in mind there might be some incidental costs that will sneak up. I would go ahead and replace the water pump and hoses while you are there, just to be safe. If installing it yourself doesn't affect the warranty, I would say go for the rebuilt 350, if you are comfortable with the shop. I wouldn't waste your time with another 305.
You can probably get it all swapped out in a weekend, if you have the hoist and all ready to go. My advice is to take your time, clean everything up as you go, and have fun.
05-13-2010, 10:32 AM | #12 |
TruckincrazY
After replacing mine myself, I would pay to have it done if I had the money. I couldn't find a place to do it for me at the time. But I was doing it all by myself. With help, it may not be that bad.
05-13-2010, 10:47 AM | #13 | |
OL BLUU
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 05-13-2010 at 10:55 AM. |
05-13-2010, 10:50 AM | #14 | |
OL BLUU
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 05-13-2010 at 10:54 AM. |
05-13-2010, 10:53 AM | #15 | |
OL BLUU
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 05-13-2010 at 10:53 AM. |
05-13-2010, 10:54 AM | #16 |
Never Satisfied
sounds like you have a plan.
1973 4x4 Blazer- Parting Out 1986 LWB Silverado Undergoing LQ4/4L80E Swap '86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566 |
05-13-2010, 10:56 AM | #17 |
That doesn't sound like too bad of a deal, Anthony.
Four Star engines used to be what everybody used when I was growing up. I think they may have been in Hutchinson, though. A lot closer to us out in the sticks.
05-13-2010, 11:09 AM | #18 |
OL BLUU
Yeah now I just need to balls up and act on it!!!
I could of done just sooo much more to the Blazer... instead of spending it on the guts of it.
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 05-13-2010 at 11:12 AM. |
05-13-2010, 11:22 AM | #19 |
Take a few pics of your progress and post.
05-13-2010, 11:52 AM | #20 |
Garage wrench
True, it's a decent amount of money to spend on something you thought was fine. But look at it this way, it's probably going to be a one time deal, it should not have to be done again for a LOOOONG time. That's the silver lining I would be forced to see
05-13-2010, 03:00 PM | #21 |
OL BLUU
Very true ^^... well I went down and finished up the details late this morning... and left it there. It'll be getting a 350, RV cam, Forged pistons and a double timing chain... the guy is straight up... I asked about the up charge on the above mentioned... he said that'll be included and not to worry about it. I'm convienced that I took the correct route this time... I normally try to do all my stuff on my own... but not this time (the $ difference didnt seem worth to me anyways). So by next week it'll have a new "heart"
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
05-14-2010, 07:56 AM | #22 |
Navy Radioman Veteran
I have the same basic setup in my '86 Jimmy. You'll be pleased with your decision.
Don't forget the pics!! Good Luck, Ken
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 |
05-14-2010, 08:55 AM | #23 |
yup,good choice anthony.i don't think that's too bad a deal.iv'e been kicking around the crate motor route and their triple that for anything that i want.your getting the most common engine on the earth.part's are everywhere and cheap.easy to add power later.and like ol kenny said........pics man
" Never look up a dead dogs butt." |
05-14-2010, 12:32 PM | #24 |
OL BLUU
Here's the pic from this morning... it's out!!
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 05-14-2010 at 12:32 PM. |
