05-12-2010, 09:39 PM | #1 |
steering problems still.. HELP HELP!!!!
so i have a 72 blazer thats ive dumped alot of money into and the steering is a pain in the butt. new everything.. someone on here said maybe its your tires.. so i changed them.. rebuilt steering box, ball joints, tierod ends everythings new. it has a 6 inch lift. i took the front shims out to see if that would help. NOPE.. still drive strange. i havent redone the brakes yet and it pulls right when i put the brakes on.. could this have something to do with it? when i hammer on the gas pedal.. it takes off straight.. once i let go of it, it seems to wonder or jerk .. whatever it does. when i turn the steering wheel all the way left (when in my driveway), the front end drivers side lifts up.. the whole corner of the blazer. when i turn right, the front end doesnt rise. could this have something to do with it? PLEASE HELP. im desperate here.. its been aligned. it has a steering stabilizer (skyjacker) i looked for cracks in the frame, cant find any.
Last edited by msgross; 05-12-2010 at 10:28 PM. Reason: removed the F bomb from title |
05-12-2010, 10:25 PM | #2 |
Re: steering problems still.. F**K HELP HELP!!!!
That sucks!
I'm no expert, But I chased a front end problem in another vehicle, replacing part after part and it ended up being a loose bolt. Double & triple check everything, then if you can find a willing buddy have them check (sometimes another pair of eyes works!) Good luck, hope you figure it out.
Dustin '97 Dodge Ram (daily driver) '71 Blazer (supposed to be a toy... insists on being a project) '85 Monte Carlo SS (project) |
05-12-2010, 10:27 PM | #3 |
please mind the language in your title,
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-12-2010, 11:19 PM | #4 | |
05-12-2010, 11:22 PM | #5 |
05-13-2010, 12:02 AM | #6 |
Future TOTM Winner
Re: steering problems still.. HELP HELP!!!!
I'm curious about the rebuilt steering box, was the "slack" ajusted out of it? Also did you do something to correct for the 6 inch lift such as a raised steering arm or drop drag link? A lot of the times with issues like you described it might be a couple different things all working together to cause a bigger problem.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 05-13-2010 at 12:03 AM. |
05-13-2010, 12:13 AM | #7 | |
05-13-2010, 12:32 AM | #8 |
should i be running a dropped drag link with the raised steering arm that came with the sky jacker kit?
05-13-2010, 12:54 AM | #9 |
does anyone have the alignment specs?? caster/camber and toe?
05-13-2010, 07:35 AM | #10 |
It's likely the brakes if it's pulling to the right when you apply the brakes. I would venture to guess that you have a bad seal on your right brake caliper and some dirt has gotten between the caliper piston and the caliper. When this happens this piston cannot retract and it stays in light contact with the rotor causing it to apply before the other side and the vehicle will pull quickly to one side.
I also had a u-joint in the front axle (I'm assuming you have a 4 wheel drive) one time to sieze cause the front end to wobble, but it only wobbled when I started to turn the wheel. Very wierd.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
05-13-2010, 07:55 AM | #11 |
seems like you are getting responses, otherwise I'd suggest the suspension or 4x4 section. I can move it if you want...
05-13-2010, 08:01 AM | #12 | |
Have you bled the brake system lately? sounds like new calipers and some new fluid are in order too, that's cheap insurance for many years of stopping power.
05-13-2010, 08:57 AM | #13 | |
05-13-2010, 09:02 AM | #14 | |
one of my u joints in the front axle was siezed aswell. so i replaced both sides. the locking hub on the drivers side is a little loose aswell. i tightned the allen screws, but its still kinda loose.. weird hey? |
05-13-2010, 09:10 AM | #15 |
im so upset about this problem.. ive spent 10's of thousands restoring it and it steering like a piece of poop. i dont even enjoy driving it.
one other thing is... the steering pump and front end (pullys) on my motor is off a 86 camero. but im told that it shouldnt be a problem. ive been saving my money to do a serpintine system. thanx everyone for your tips and help. |
05-13-2010, 09:17 AM | #16 |
One other thing, front brake hoses, but you probably installed longer ones when you installed the lift kit. The rubber inside the brake hose would separate inside and block the return of the fluid to the master cylinder acting as a check valve and would cause the brake to apply quicker while driving but would bleed off when parked.
05-13-2010, 01:36 PM | #17 |
If you don't want to change the pitman arm then look into the S shaped drag link...
05-13-2010, 01:47 PM | #18 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Howz the rag joint?
That wouldn't cause pulling but it can cause "loose" feeling steering.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
05-13-2010, 02:47 PM | #19 |
New Member
You said it was a problem even before the lift? I'd wonder if the truck might have been wrecked at some point in the past. Might have a tweaked frame.
05-13-2010, 04:29 PM | #20 |
If the truck tends to wander, check your camber and especially your caster. Most corner alignment shops only check the toe-in on our trucks since they don't consider caster and camber to be adjustable (which they are). These trucks are spec'd with something like 4 degrees of caster (steering knuckles leaning back) and something like 2 degrees of camber (top of tires leaning out). When you add a lift in the front, back, or both, the caster can get screwed up. If you have too little caster, the truck will not want to track straight, or will not track consistently. Just a thought. Good luck.
05-13-2010, 08:40 PM | #21 |
05-13-2010, 08:41 PM | #22 |
05-13-2010, 08:43 PM | #23 |
that could be it.. would that cause some weird steering? maybe i should take it to a frame shop. its 37 years old.. who knows whats happined to it as far as accidents.
05-13-2010, 08:45 PM | #24 | |
05-14-2010, 12:44 PM | #25 |
New Member
It could if the frame is bent it wouldn't track straight. A friend of mine had a truck that had been wrecked and had me drive it after he had a few too many cocktails and that thing was a workout just keeping it on the road.
