Old 05-13-2010, 09:07 AM   #1
cl08
Rear frame section????
How much difference is the rear frame secton from a 67-68 to a 64-66?
Getting me a free leaking aluminum rear mount gas tank this weekend from a 68. Luckly the business I am in, I have access to an aluminum tank fabricator that can fix the leak or leaks for free as well I hope. Can't beat that.
Thanks guys,
Cody
cl08 is offline   Reply With Quote
Old 05-13-2010, 01:49 PM   #2
SCOTI
SCOTI's Avatar
Re: Rear frame section????
Thanks guys,
Cody
Not much. The holes for the bed bolts are slightly different (elongated on the later frames). The Panhard mounts are different as well. Frame rails are the same....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 05-13-2010, 02:48 PM   #3
cl08
So there is a good chance the tank can work?
Old 05-13-2010, 04:04 PM   #4
SCOTI
SCOTI's Avatar
Yes. A 69-72 blazer tank would fit & is a common swap so other rear tanks that would fit a 67-72 should work as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-13-2010, 04:20 PM   #5
cl08
Thanks that makes me happy.
My boss has a 89-91 parts Suburan. I am going to rob the steering column, foot emergency brake setup, hood release, 700r4. Is it worth using the front suspension from too?
Old 05-13-2010, 06:26 PM   #6
chevy283
chevy283's Avatar
yeap i had a 91 sub front suspension on my 65
65 c10 tore apart
70 c10 305/350th
chevy283 is offline   Reply With Quote
Old 05-13-2010, 09:53 PM   #7
SCOTI
SCOTI's Avatar
Definitely worth it if the price is right.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-14-2010, 09:06 AM   #8
cl08
Suburban price is FREE!!!! Just have to pull the parts. He bought it for the front sheet metal for his 74.
These parts will bolt up right or little to no fabrication correct?
Old 05-15-2010, 12:35 AM   #9
Captainfab
60-66 Nut
Yes the '89-'91 2wd Suburban front suspension, brakes and steering will bolt up with little modification and a couple aftermarket brackets. They are the same as the '73-'87 pickups.
