Old 05-15-2010, 08:09 PM   #1
Matt Man
Matt Man's Avatar
Air conditioning air flow
Well my ac has been replaced with 134 so it works pretty good blows plenty cold,
anyway it blows pretty good out the top but blows like a tornado out the bottom i was wondering if theres something i can do to put more of the air out of the bottom to the top vents? i tried adjusting it with the lever under the glove box but that didnt work. Is it normal to blow out the bottom that much when the ac is on high?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-15-2010, 09:23 PM   #2
tucsonjwt
Re: Air conditioning air flow
Here are some things I have experienced with my 83 C20:
Make sure that all of the air ducts are seated in their adjoining duct (one slips into the other). My ducts have often been dislodged somewhat and that messes up the airflow. Start from the center air box below the dash and go from there.
I like the air to blow directly on me, not the floor, so make sure that the ducts going to the outboard dash vanes and the center vane are intact. I got some HVAC shinny silver tape (not duct tape) and taped the duct joints to seal them and prevent air loss under the dash. It is a real pain to get these ducts in place and stay there, especially the outside vanes and the center vane. I had to remove the dash to do mine right. Also, make sure that the air hose going from the center under dash distribution box to the right side dash vane is in place - you can remove the glove box and get at this somewhat.
I close the passenger side dash vane and point the other dash vanes at my face.
If you do these things you should get about the same amount out of the bottom as the top (for the driver's side).
When I had my square bodies converted to 134 from R12, I noticed a significant drop in cooling - still cool but not like R12. With the R12, the A/C cooled so much that the defects I described above didn't seem to make much difference. Of course, it is 115 degrees in the shade in the Arizona desert, so we notice marginal cooling right away.
I know this duct sealing is a pain, but I found it was worth the effort. Good luck.
tucsonjwt is offline   Reply With Quote
