Old 05-17-2010, 10:52 AM   #1
BlueJeep
BlueJeep's Avatar
S10 frame guys battery location?
For those of you who've done the S10 swap on your AD's, where are you putting your battery? If I can't find a better idea, mine's going on the passenger side in the engine compartment. Getting close to having to wire mine, and the battery will be my starting point.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-17-2010, 11:06 AM   #2
britnjc
britnjc's Avatar
Re: S10 frame guys battery location?
passenger side firewall is where mine is
britnjc is offline   Reply With Quote
Old 05-17-2010, 11:08 AM   #3
Thadious
Frenched mine about 4" down into the passenger's fender, think Jeffs51chevy did as well (I'm sure he'll chime in, and it's on his build thread.) Gives enough room for the heater core hoses to come out.
Cheers,
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 05-17-2010, 11:30 AM   #4
BlueJeep
BlueJeep's Avatar
Cheers,
Ted.
Any concern with that tire contacting it? Any pictures of how you oriented the battery (parallel or perpendicular to the firewall)?
Trying to keep as much room available for a squirter tank and coolant recovery tank as possible, as well as the heat and A/C lines you've referenced.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 05-17-2010, 02:34 PM   #5
Thadious
Placed it about 1" from the side of the fender and about 1-1 1/2" from the firewall, perpendicular and was tons of room with the tires.
Ted.
PS Will see if I can find a pic of it when I get home for ya.
Old 05-17-2010, 02:56 PM   #6
1952ssr
1952ssr's Avatar
PLAN A: make custom inner fenders and core support simular to a S10 and place it at the right front. PLAN B: place it back on the frame rail back at the rear right fender behind the wheel.
1952ssr is offline   Reply With Quote
Old 05-17-2010, 03:23 PM   #7
jeffs51chevy
jeffs51chevy's Avatar
Yup, 4 1/2 down and about 1 1/2 away from the inner/outer fender transition. As stated, tons of room. Search "S10 Swappers Battery Location ideas" posted in February. It should give you a couple more ideas. I will try to find a finished photo of mine. I know Atomsplitter has a great photo of the finished product.
Jeff
jeffs51chevy is offline   Reply With Quote
